  3. Combinational Circuit In RTL Compiler
  • Views 15474
Kliatakis
Kliatakis over 17 years ago
 Hello! I am a newbie in RTL compiler and SOC encounter and I would like to ask you a question.
now that i have to deal with cores that have a clock the script that i run in RTL compiler is the following:
read_hdl fpu_div.v
elaborate
dc::create _clock [dc::get_ports clk] -period 5 -waveform {0 2.5}
dc::set_input_delay 1 -clock {clk} [dc::all_inputs]
dc::set_output_delay 0.5 -clock {clk} [dc::all_outputs]
dc::set_load 0.001 [dc::all_outputs]
dc:: set_drive 1.2 [dc::all inputs]
report timing > reports/repo_DP_FP_DIV
report area >>reports/repo_DP_FP_DIV
report power >> reports/repo_DP_FP_DIV
write_sdc > sdc/sdc_rc_file_DP_FP_DIV
write -mapped > netlists/DP_FP_DIV.v
write_sdf > DP_FP_DIV_sdf
If i have to deal with a core(for example a comparator) which is not clock triggered what do i have to do in RTL compiler? i do not use the commands that concern clock obviously, but do i have to put anything else?
because if i do this i get this message:
Warning : Possible timing problems have been detected in this design. [TIM-11]
        : The design is 'My_Comparator_128'.
        : Use 'report timing -lint' for more information.
 Thanks In advance!!!
  • skillUser
    skillUser over 17 years ago
     This is probably not the best forum to ask questions on SOC Encounter or RTL Compiler, please try the Digital Implementation forum.
    Lawrence.
  • Kliatakis
    Oh sorry! i will ask there!thanks!
