  3. Drop Down menu
  • Views 17325
Drop Down menu
AnuJoamon
AnuJoamon over 17 years ago
my skill code creates a drop down menu in the layout window. But when I load the skill again i get an error -
          "*Error* User post install trigger already registered for viewType maskLayout."
How to update the code for the removing the error?
Anuj
  • AnuJoamon
    Sorry, it is Pull Down menu, with the code like
    procedure( trUserPostInstallTrigger(args)
     hiInsertBannerMenu(
      args->window
      trCreateLayoutPulldownMenu()
      length( hiGetBannerMenus( args->window))
     ) ; hiInsertBannerMenu
    ) ; procedure trUserPostInstallTrigger
    deRegUserTriggers("maskLayout" nil nil 'trUserPostInstallTrigger)
  • AnuJoamon
    the pull-down menu is created
    procedure( trCreateLayoutPulldownMenu()
     if( boundp( 'trLayoutPulldownMenu ) then
     else
      hiCreatePulldownMenu(
      "TEST"
      list(
       hiCreateMenuItem( ; list of menu items
        ?name 'CleanLSW
        ?itemText "TEST"
        ?callback  "LAYOUT_TEST()"
        ) ; hiCreateMenuItem
       ) ; list
      ) ; hiCreatePulldownMenu
     ) ; if boundp
    ) ; procedure trCreateLayoutPulldownMenu
     Please also suggest, if I can write the Menu create procedures above the callback procedures or it needs to be in bottom-up approach.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     Hi Anu
     To answer your last question, you can define the procedures you are using in the menu before or after the menu item is defined. It is independent of the item definition and will only cause an error if it is not available when the menu button is pushed.
    Your initial issue is because there is already user triggers set for maskLayout.  You have to get that information and add your trigger to it.Note that if there is more than one procedure defined for a trigger, you will only get the first procedure.
    appInfo = deGetAppInfo( "maskLayout" ) ;returns a property list where:
    userApp = appInfo->userAppTrigList ; This is the user pre install trigger
    userMenu = appInfo->userMenuTrigList ; This is the user menu trigger
    userPost = appinfo->userPostInstallTrigList ; This is the post intall list
     deUnRegUserTriggers("maskLayout") ; Unregister the triggers
    deRegUserTriggers( "maskLayout" userApp userMenu 'trPostUserInstallTrigger)
     You probably can find more info on these in the Virtuoso Design Environment SKILL Reference.
     Ted
