  3. Creating circle in Virtuoso
  • Replies 8
  • Subscribers 136
  • Views 23289
zhengli
zhengli over 17 years ago
Hi, Can any one help me how to create a circle snapping to manufacturing grids defined in the technology file? I want to create a circle shape in virtuoso layout editor XL included in iCC 6.1.3. I found out that circle is actually created as a polygon. The problem is that when I export the layout into GDSII file, the ending points of the circle does not snapping to the manufacturing grids. I tried to create several real polygons, it is snapping to the grids. So I was wondering if there should be some additional setting to force circle shape snapping to grids. Please let me know if there is any solutions. Thanks a lot
  • skillUser
    skillUser over 17 years ago
    Unless I am mistaken, it is not mathematically possible to snap a circle so that it is all on grid, but this might just be the terminology that you are using.
    After creating a circle you can use Edit -> Advanced-> Convert to Polygon to manually control the conversion of ellipses, donuts and circles to polygonal shapes.  There is a setting "Conic Sides" on the Layout Editor Options form which defaults to 20, but you can try other values. This is also available as a .cdsenv variable setting, for example:
    layout numSides int 20
     I hope that this information helps you.
    Lawrence.
  • zhengli
    Thank you very much. What I want is actually a polygonal shape like a circle which is snapping to grids. However, even if I convert the circle to polygonal shape using Edit-> Advanced-> Convert, the resulting polygon are still not snapping to manufacturing grids. Conic slides can control how many sides I can have, but it seems that it doesn't help in this case. Is there any way that I can tell virtuoso to snapping all the points of the polygon to the grids? Thanks in advance! Best, Zheng
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     You will have to calculate the coordinates to get them to snap to the manufacturing grid. Calculate your angle based on the number of segments and that will give you the angle to calcuate each segment. Digging out your old trig book, sine of the angle is used to calculate the X value, cosine the Y value (the radius is the hypotenuse). Round the values to the manufacturing grid as you calculate them and you will get a slightly jaggy circle with everything on grid. You can do some smoothing after you calculate the points, adjusting the length of each segment independently.
    Ted
    archive over 17 years ago
    I encountered the same problem and wrote a pcell to do it for me: http://atchoo.org/tools/cadence/circlePcell.il
    Let me know if you have any problems with it!
     Cheers,
    Roger
  • EricCDN
    EricCDN over 17 years ago
    See also Sourcelink Solution 1800103:
    http://sourcelink.cadence.com/docs/db/kdb/1994/Sept/1800103.html
  • zhengli
    Thanks. This one seem to work. However, I do not understand why a compensate factor need to be added. This factor is get from
    compFactor = 1 / rep~>DBUPerUU
     and used as follows:
          procedure(  CCSroundCoord(  point xgrid ygrid compFactor )
              prog(  ( x y )
                   x=round( ( xCoord( point ) + compFactor ) / xgrid ) * xgrid
                   y=round( ( yCoord( point ) + compFactor ) / ygrid ) * ygrid
                   return( list(  x y  ) )
    DBUPerUU represents number of database units in one user unit. In my system it is 1000. If I add this one, the whole calculation will be screwed up.
    Andrew Beckett over 17 years ago
    This is to compensate for small rounding errors that can occur whenever doing floating point arithmetic.
    For example, if you do:
    floor(1.005/0.005) you end up with 200, not 201, due to the fact that the result of the division is a tiny amount less than 201.
    Adding a small "epsilon" compensates for this - in this case, it's adding 1 DBU.
    However, since the calculation in this function is using round(), there should really be no need to do this, because it will round to the nearest, rather than round down or up. So I think it's redundant. It shouldn't really break anything (assuming the grid is not 1 DBU!), but it doesn't do anything useful.
  • ejm20
    ejm20 over 14 years ago
     Hi Roger - This is a very cool pCell, nicely done!!
     Rick
