  3. spectre version error
  • Views 17936
sabertooth
sabertooth over 17 years ago
Hi everyone.
My issue is as follows:
1. I set up the cadence environment.
2. Now I fire up the workbench and enter a schematic using Virtuoso composer.
3.  I open ADE and when I run the simulation, I see the following error in CIW.
 *Error* The 'spectre' executable that you are using is an older version.
        Use MMSIM60 or later version of Spectre with this release.
        To check the spectre version, run 'spectre -W'.
Here are some useful messages from CIW just before this:
*WARNING* (icLic-3) Could not get license Analog_Design_Environment_L
(deLicense-6) Checked out the license for ADE XL to run ADE L
Loading awv.cxt
Loading socket.cxt
Loading alvs.cxt
ERROR: can't determine installation root.
       can't create rooted path to arg0 "viva"
       using current working directory or $PATH: /usr/licensed/cadence-20060508/SOC52.sun4v/tools/bin:/usr/licensed/cadence-20060508/IFV62.sun4v/tools/bin:/usr/licensed/cadence-20060508/MMSIM62.sun4v/tools.sun4v/bin:/usr/licensed/cadence-20060508/IC610.sun4v/tools/bin:/usr/licensed/synopsys/hspice_A-2007.09/hspice/bin:/usr/licensed/synopsys/mw_A-2007.12-SP1/bin/SUN.64:/usr/licensed/synopsys/jupiterxt_Z-2007.03-SP5/bin/SUN.64:/usr/licensed/synopsys/astro_Z-2007.03-SP5/bin/SUN.64:/usr/licensed/synopsys/spiceexplorer_C-2009.03/c2009.03/sx_c2009_03/bin:/usr/licensed/synopsys/taurus_tsuprem4_A-2007.12/bin:/usr/licensed/synopsys/vcs-mx_B-2008.12/bin:/usr/licensed/synopsys/mw_A-2007.12-SP1/bin:/usr/licensed/synopsys/txs_A-2007.12-SP1/bin:/usr/licensed/synopsys/pts_Z-2007.06-SP2/bin:/usr/licensed/synopsys/taurus_medici_Z-2007.03/bin:/usr/licensed/synopsys/sentaurus_Z-2007.03/bin:/usr/licensed/synopsys/syn_B-2008.09-SP3/bin:/usr/psr.oit/solaris10/2007-2.0/bin:/usr/psr.oit/solaris10/2007-2.0/sbin:/usr/psr.oit/solaris10/2007-2.0/local/bin:/usr/psr.oit/solaris10/2007-2.0/local/sbin:/u/mshoaib/bin:/usr/licensed/bin:/usr/openwin/bin:/usr/ccs/bin:/opt/SUNWspro/bin:/usr/ucb:/usr/local/bin:/bin:/sbin:/usr/bin:/usr/sbin:.
Loading adexl.cxt
*Error*   Failed to launch ViVA. There is a problem with the DFII
          installation hierarchy (Exit Code = 1).
          For further assistance, contact Cadence Customer Support
          with the diagnostic information available in the log file.
*Info*    Dumping diagnostic information ....
/usr/licensed/cadence-20060508/IC610.sun4v/tools.sun4v/dfII/bin/checkwavescan: wavescan: not found
I tried to check the path variable and even typed "Spectre -W/-V" which showed version 6.2 being in the path.
I do not understand why is the tool trying to access the older version of spectre even though, the first occurence of the executable in ($PATH, which is written above) refers to the higher version of 6.2.
I have the following questions:
1. Is the error "cannot load ViVA" related to cadence not finding the new spectre executable ?
2. How can I set the path within the CIW (will using SkillSetPath, not affect the other tools ?)
3. Is there a problem with my $PATH ?
Thanks in anticipation for your assistance with this !!
- Shoaib
  • Jim McMahon
    Jim McMahon over 17 years ago
    Hi Shoaib
     I noticed from your error message that $CDS_INST_DIR/tools/dfII/bin does not appear to be in your $PATH. Not sure how you are able to launch virtuoso without this in your $PATH.... Your cadence environment setup requires the following 2 paths:
            $CDS_INST_DIR/tools/bin
    This should solve the earlier VIVA warnings and perhaps answers question #3.
    After fixing the $PATH, run "which virtuoso" and " virtuoso -W" to make sure it is picking up the correct virtuoso executable. Try the same for the spectre executable.
     - I don't know what role the viva issue this is playing in your spetre issue.
    - For question #2 above, I you trying to set the SKILL path or the unix $PATH?
    Assuming UNIX path:
     setShellEnvVar("PATH=<X>" ) ;;;where <X> = desired PATH
