  3. Sweeping variable values within Monte Carlo Simulation
  • Views 15542
Sirrius
Sirrius over 17 years ago
Hello All,
 I am trying to sweep the value of a variable "sh_delay_time" within monte-carlo run. The idea is that for every "instance" of the circuit created during monte-carlo run, (the parameter to be statistically varied is threshold voltage here ), I wish to sweep  a design variable.
So, if the design variable can take 10 different values, the monte-carlo simulation will essentially run 10 simulations with a particular value of threshold voltage, and repeat the simulations for the number of runs defined by ?numIters value. Therefore, I will get 10 results for every monte-carlo run. I tried this with the script:
 ocnWaveformTool( 'wavescan )
simulator('spectre)
design(     "/var/home/dr3sg/scratch/Braun_Multiplier/spectre/extracted/netlist/netlist")
resultsDir( "/var/home/dr3sg/scratch/Braun_Multiplier/spectre/extracted" )
modelFile(
    '("/var/home/dr3sg/Virtuoso_WithoutPads/ami06P.m" "")
    '("/var/home/dr3sg/Virtuoso_WithoutPads/ami06N.m" "")
stimulusFile( ?xlate nil
    "/var/home/dr3sg/scratch/Braun_Multiplier/spectre/extracted/netlist/_graphical_stimuli.scs")
analysis( 'tran ?stop "300n" ?errpreset "moderate")
skewstep_size_list = " 10.35n 10.4n "
temp(27)
option(    'temp  "27.0" )
envOption(
    'firstRun  nil
monteCarlo( ?numIters "5" ?startIter "1"
    ?analysisVariation 'processAndMismatch ?sweptParam "skew_step_size"
    ?sweptParamVals skewstep_size_list ?saveData t
    ?nomRun "yes" ?append nil
    ?saveProcessParams t
desVar(      "sh_delay_time" (31 - skew_step_size)*1n    )
monteExpr( "value_cmp0" "value(VT(\"/cmp_out<0>\") 3e-07)" )
monteExpr( "value_cmp1" "value(VT(\"/cmp_out<1>\") 3e-07)" )
monteExpr( "value_cmp2" "value(VT(\"/cmp_out<2>\") 3e-07)" )
monteExpr( "value_cmp3" "value(VT(\"/cmp_out<3>\") 3e-07)" )
monteExpr( "value_cmp4" "value(VT(\"/cmp_out<4>\") 3e-07)" )
monteExpr( "value_cmp5" "value(VT(\"/cmp_out<5>\") 3e-07)" )
monteExpr( "value_cmp6" "value(VT(\"/cmp_out<6>\") 3e-07)" )
monteExpr( "value_cmp7" "value(VT(\"/cmp_out<7>\") 3e-07)" )
monteExpr( "value_cmp8" "value(VT(\"/cmp_out<8>\") 3e-07)" )
monteExpr( "value_cmp9" "value(VT(\"/cmp_out<9>\") 3e-07)" )
monteExpr( "value_cmp10" "value(VT(\"/cmp_out<10>\") 3e-07)" )
monteExpr( "value_cmp11" "value(VT(\"/cmp_out<11>\") 3e-07)" )
monteExpr( "value_cmp12" "value(VT(\"/cmp_out<12>\") 3e-07)" )
monteExpr( "value_cmp13" "value(VT(\"/cmp_out<13>\") 3e-07)" )
monteExpr( "value_cmp14" "value(VT(\"/cmp_out<14>\") 3e-07)" )
monteExpr( "value_cmp15" "value(VT(\"/cmp_out<15>\") 3e-07)" )
monteRun()
delete('monteExpr)
delete('monteCarlo)
I get an error message: [Default-writer-method] generic: amcSetParamVals class: List
I also tried this script:
;setup the simulator
simulator('spectre)
;Point to the correct netlist
;setup the results directory
;set the model file
modelFile(
;set the stimulus file
;run analysis
;create a list containing the design variable: This is the variable to be swept
skewstep_list = " 7.85n 7.9n 7.95n 8n 8.05n 8.1n 8.15n 8.2n 8.25n 8.3n 8.35n 8.4n 8.45n 8.5n 8.55n 8.6n 8.65n 8.7n 8.75n 8.8n 8.85n 8.9n 8.95n 9n 9.05n 9.1n 9.15n 9.2n 9.25n 9.3n 9.35n 9.4n 9.45n 9.5n 9.55n 9.6n 9.65n 9.7n 9.75n 9.8n 9.85n 9.9n 10n 10.05n 10.1n 10.15n 10.2n 10.25n 10.3n 10.35n 10.4n 10.45n 10.5n 10.55n 10.6n 10.65n 10.7n 10.75n 10.8n 10.85n 10.9n 10.95n 11n "
;run the simulation for all the elements in the list
;copy the entire list again
desVar(      "sh_delay_time" "\" 7.85n 7.9n 7.95n 8n 8.05n 8.1n 8.15n 8.2n 8.25n 8.3n 8.35n 8.4n 8.45n 8.5n 8.55n 8.6n 8.65n 8.7n 8.75n 8.8n 8.85n 8.9n 8.95n 9n 9.05n 9.1n 9.15n 9.2n 9.25n 9.3n 9.35n 9.4n 9.45n 9.5n 9.55n 9.6n 9.65n 9.7n 9.75n 9.8n 9.85n 9.9n 10n 10.05n 10.1n 10.15n 10.2n 10.25n 10.3n 10.35n 10.4n 10.45n 10.5n 10.55n 10.6n 10.65n 10.7n 10.75n 10.8n 10.85n 10.9n 10.95n 11n \""    )
;set temperature
temp(27)
envOption(
    'firstRun  nil
;MonteCarlo
monteCarlo( ?numIters "50" ?startIter "1"
    ?analysisVariation 'processAndMismatch ?sweptParam "sh_delay_time"
    ?sweptParamVals skewstep_list ?saveData t
monteExpr( "value_cmp0" "value(VT(\"/cmp_out<0>\") 300n)" )
monteExpr( "value_cmp1" "value(VT(\"/cmp_out<1>\") 300n)" )
monteExpr( "value_cmp2" "value(VT(\"/cmp_out<2>\") 300n)" )
monteExpr( "value_cmp3" "value(VT(\"/cmp_out<3>\") 300n)" )
monteExpr( "value_cmp4" "value(VT(\"/cmp_out<4>\") 300n)" )
monteExpr( "value_cmp5" "value(VT(\"/cmp_out<5>\") 300n)" )
monteExpr( "value_cmp6" "value(VT(\"/cmp_out<6>\") 300n)" )
monteExpr( "value_cmp7" "value(VT(\"/cmp_out<7>\") 300n)" )
monteExpr( "value_cmp8" "value(VT(\"/cmp_out<8>\") 300n)" )
monteExpr( "value_cmp9" "value(VT(\"/cmp_out<9>\") 300n)" )
monteExpr( "value_cmp10" "value(VT(\"/cmp_out<10>\") 300n)" )
monteExpr( "value_cmp11" "value(VT(\"/cmp_out<11>\") 300n)" )
monteExpr( "value_cmp12" "value(VT(\"/cmp_out<12>\") 300n)" )
monteExpr( "value_cmp13" "value(VT(\"/cmp_out<13>\") 300n)" )
monteExpr( "value_cmp14" "value(VT(\"/cmp_out<14>\") 300n)" )
monteExpr( "value_cmp15" "value(VT(\"/cmp_out<15>\") 300n)" )
monteRun()
cmp_out is a bus, and I am interested in knowing its volage at 300ns.
The above script runs without warnings or errors, but the results that I get are incorrect.
 Just to complete the information, the script below works and it was generated from the tool itself. It does not however sweep the variable within each monte-carlo run.
simulator( 'spectre )
design(     "/net/plato/scratch/dr3sg/Braun_Multiplier/spectre/extracted/netlist/netlist")
resultsDir( "/net/plato/scratch/dr3sg/Braun_Multiplier/spectre/extracted" )
modelFile(
    '("/homenfs/class3u/dr3sg/Virtuoso_WithoutPads/ami06P.m" "")
    '("/homenfs/class3u/dr3sg/Virtuoso_WithoutPads/ami06N.m" "")
    "/net/plato/scratch/dr3sg/Braun_Multiplier/spectre/extracted/netlist/_graphical_stimuli.scs")
analysis('tran ?stop "300n"  ?errpreset "moderate"  )
desVar(      "sh_delay_time" 20.65n    )
envOption(
    'firstRun  nil
temp( 27.0 )
    ?analysisVariation 'processAndMismatch ?sweptParam "None"
    ?sweptParamVals "27" ?saveData nil
monteRun()
 Can someone please help?
 Thank you very much!
 Regards
Sirrius
