  3. Using the Virtuoso Analog Circuit Optimization to iterate...
  • Views 15429
Using the Virtuoso Analog Circuit Optimization to iterate on layout geometries
gsimard
gsimard over 17 years ago
Hello all,
Is there a way to automate an optimization process that would need a post-layout extracted view to get its goals ?
For example, if I have written a PCELL in skill that generates a ring oscillator from transistors. The sizes of these transistors and number of inverters can be specified on the instance of the PCELL in the level 0 layout.
Then I need to place pins and labels over the right metal parts to meet my symbol's pins.
After that, I execute a layout extraction, which I read is toolkit specific and in my case could be launched from command line.
I then run a simulation from the analog environment in my test bench schematic which uses the symbol of the oscillator and I use the hierarchy editor to specify that it should use the extracted view for simulation.
I then calculate the frequency of the oscillator with the calculator (DFT, max).
The goal would then be that this frequency reach say 5 MHz, so I would like to setup the analog circuit optimization to iterate this procedure.
Can this be done easily ? If not easily, I am willing to code a bit, but I would need pointers for this one !
Thank you,
Guillaume Simard
