  3. Cadence IC 6.1.3 Simualtion
  • Replies 9
  • Views 8587
StreamCX
StreamCX over 17 years ago
I have Cadence 6.1.3 installed in my department.
I want to run some analyses in schematic.
For example, transient from 05B_AnalogBlockDesignOptimization tutorial of AMSKIT.
[URL=http://img269.imageshack.us/my.php?image=errorq.png][IMG]img269.imageshack.us/.../URL]
When i try to simulate, appears message that i need to write path to some libs like npn, pnp.
[URL=http://img269.imageshack.us/my.php?image=path.png][IMG]img269.imageshack.us/.../URL]
Simulation does not passsed.
 How can I fix errors?
  • skillUser
    skillUser over 17 years ago
    I don't know what path you will need to put, but it looks to me as though the model library is missing from the Analog Design Environment model library form.  There is most likely just one file, let's call it "models.scs", which will need to be included.  This may also have "sections", you may wish to include the right one, or just use a default (e.g. typtyp or "TT").
    I hope that this helps.
    Lawrence.
  • StreamCX
    Thanks, skillUser
    How can I use default?
    What is "typtyp"?
  • StreamCX
    Topic has been upgrated with images.
    I have been trying to include pmos2v.scs and nmos2v.scs files but error messages was appear in Libmanager,log
    Nothing changes with simulation errors.
  • haikom
    haikom over 17 years ago
    do you mean the libXt.so... error? Search for this lib inside the cadence installation tree. If you find this file, add the path to the environment variable LD_LIBRARY_PATH. Please take care whether you are on a 32- or 64-bit machine and choose the correct directory.
     Regards
    haiko
    Andrew Beckett over 17 years ago
    It should not be necessary to update your LD_LIBRARY_PATH to include any directories from the Cadence installations; this should be handled by the wrapper scripts in the installation that invoke the executables. These also take care of ensuring that either the 32 or 64 bit libraries are picked up, depending on the value of $CDS_AUTO_64BIT or passing the -64 switch on the command line.
  • StreamCX
     I don`t know what to do. :-(
    Given the names of the missing models, I'm assuming that you may be using a "gpdk" from Cadence? If so, do you have any entries in Setup->Model Libraries in ADE? You need (as Lawrence said) to reference the model files from within the design kit. This would normally be done automatically by the code loaded when the library is opened.
    What design kit are you using? Very little information to us makes it very hard to guess what your problem is...
  • StreamCX
    Example is from AMSKIT.
    I dont` have access to auditory now and can`t answer some questions.
  • StreamCX
