  3. Question about auCdl netlisting from the command line
  • Views 15208
SkillStudent
SkillStudent over 17 years ago
 Is there a way to netlist out more than one cell by running si only once?, I mean right now you have to set simCellName = "<cellName>" in the si.env file and run si, I was wondering if there is a way to set a list of cells in the si.env file.
    archive over 17 years ago
      Only one cell can be netlisted at a time.  You can write a shell script to iterate si over a list of cell names. Check out solution 11005433 in sourcelink.cadence.com
    Samir Jafferali
