  3. Model file for schottky in analogLib in Cadence
  • Views 16875
Cheerful
Cheerful over 17 years ago
Hi
 i am running spectre for a circuit. The schottky requires model name. I get the following data from the schottky manufacturer and modified for spectre
model s_diode diode
+is=0.000182183 rs=0.0312608 n=1.40283 eg=0.576586
+xti=0.000499955 bv=1000 ibv=0.0001 cjo=4.92728e-10
+vj=0.573693 m=0.464284 fc=0.5 tt=1e-09
+kf=0 af=1
 Is my langange correct? because i have a warning that says Junction current exceeds "imelt". The results computed by Virtusoso Spectre are now incorrect because the junction current model has been linearised.The Junction current exceeds "imax".
 please teach me. thank you alot for your kind teaching.
  • Jim McMahon
    Jim McMahon over 17 years ago
    The forward or reverse current must be exceeding 1A for this diode. You can increase this limit by adding a "imax" parameter to the model:
     model s_diode diode
    +kf=0 af=1 imax=100
     The default current density limit of 1A is considered reasonible for the diode devices typically found on an IC. Of course discrete and diodes designed for high power applications may carry higher currents.
    Jim
