  3. Monte Carlo - Temperature sweep
  • Views 3717
Renju R Thomas
Renju R Thomas over 17 years ago
Dear all,
I need to do monte carlo analysis for my Temp Sensor Circuit.
I tried the dc sweep ........
.DC TEMP 25 125 1 SWEEP  MONTE=100
But the output is not the one expected.
As,
.DC MONTE=100
and
.DC TEMP 25 125 1
are working fine and the output is as expected, I doubt whether we can combine temperature sweep with MC analysis.
I also tried,
.DC TEMP LIN 125 1 125 SWEEP MONTE=100
Please help.
Thanks & Regards,
Renju
    Andrew Beckett over 17 years ago
    Renju,
    What simulator are you using? That's not spectre syntax (certainly not for monte carlo). With spectre you'd do something like:
    mnt montecarlo numruns=100 variations=all {
      dc dc param=temp start=1 stop=125 lin=125
    See "spectre -h montecarlo" and "spectre -h dc" for more details on the syntax.
    If you're using a different simulator, please say which (and bear in mind that this is a Cadence forum in case you're using a non-Cadence simulator...).
