  3. setting QRC UI in Virtuoso layout editor
  • Subscribers 133
  • Views 18634
archive over 17 years ago
I am using QRC (EXT8.1 version) for extraction. I have set the
QRC_HOME varible properly. In the $path I set this varible before CDS_HOME. When I open Layout editor, I am not seeing
QRC tab in the GUI.
I want to see QRC in the Layout editor.
Is any seetings I need to do?
Please help me
Thanks in advance
Chaitanya.
    Andrew Beckett over 17 years ago
    Which IC version are you using? You need to be using:
        5.1.41_ISR: 5.10.41.500.5.123
        5.1.41_USR6: 5.10.41_USR6.10
        6.1.1_ISR : IC6.1.1.500.59
        6.1.2_ISR : IC6.1.2.500.17
     or later.
    Also you must not have ASSURAHOME set, otherwise the QRC menu does not appear, and instead you access it via Assura->QRC
  • tkhan
    tkhan over 17 years ago
    Can you get the QRC menu in EXT7.1 also or just for EXT8.1? I am using IC sub-version 5.10.41.500.5.128 and I have to launch QRC by Assura->Run RCX after setting QRC_ENABLE_EXTRACTION="t"
     The QRC menu is only supported from EXT81 onwards, AFAIK.
    Thanks for the suggestions andrew.
     Does IC 5.1.41_USR5  support EXT8.1?
    Chaitanya.
    I believe so, but you won't get the QRC menu unless you use a later IC version than USR5, as I said earlier... the first version was .5.123 which is an ISR after USR5 (that's what the 5 means in the version number).
