  3. CellPlanner?
  • Views 14801
CellPlanner?
Mifo
Mifo over 17 years ago
Where do I find info about CellPlanner?
Has enybody used it?
Regards Mifo
  • craigth
    craigth over 17 years ago
    You can find the VLS GXL Cell Planner feature documented in the IC613 Virtuoso Analog Placement User Guide > Cell Planner. The documentation links point to Sourcelink documentation which is available with a Sourcelink accout.
     If you need assistance in using the Cell Planner contact Cadence Custom Support or your local Field Application Engineer.
