  3. How to enable Spectre autosave the results everytime i run...
  • Views 14923
How to enable Spectre autosave the results everytime i run it!
sharezhao
sharezhao over 17 years ago
Dear all!
I'm using spectre as simulation tool in vituoso 5141. How can make spectre atuosave the results such as ten last times results? now if I want to see the voltage of some nets of last time, i have to change to former parameters and run it again. That is very inconvenient. So what should i do?
Thank you!
Best regards!
    Andrew Beckett over 17 years ago
    This .cdsenv setting should do it:
    asimenv.misc  numberOfSavedRuns int    10
    or from SKILL:
    envSetVal("asimenv.misc" "numberOfSavedRuns" 'int 10)
    It's covered in the <instdir>/doc/anasimhelp/anasimhelp.pdf
  • sharezhao
    Dear Andrew!
    You are right, Thank you so much. This problem have been annoying me for a long time. You answer is right on the spot. By the way,  "asimenv.misc  numberOfSavedRuns int    10" is in the .cdsinit.  Sincere appeciation !!!
    Best regerds
