  3. Cadence 6.1.3 netlisting
  • Subscribers 133
  • Views 7435
StreamCX
StreamCX over 17 years ago
I try to run simulate in scheme of MUX
[URL=http://img190.imageshack.us/my.php?image=mymux1.png][img]img190.imageshack.us/.../URL]
[URL=http://img507.imageshack.us/my.php?image=v2mux.png][IMG]img507.imageshack.us/.../URL]
I have run ADE L
When I try to netlist this message appears
Begin Incremental Netlisting May 22 09:53:47 2009
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'spectre cmos_sch cmos.sch schematic veriloga', for the
instance 'V2' in cell 'Elem'. Either add one of these views to the library 'analogLib',
cell 'vam' or modify the view list to contain an existing view.
End netlisting May 22 09:53:47 2009
ERROR (OSSHNL): Error(s) found during netlisting. The netlist may be corrupt
or may not be produced at all.
To generate correct netlist, fix the errors and re-netlist.
      ...unsuccessful.
How can I fix this errors?
And another problem:
when I try to add an instance nothing appears.
[URL=http://img413.imageshack.us/my.php?image=instance.png][IMG]img413.imageshack.us/.../URL]
How fix it?
    Andrew Beckett over 17 years ago
    vam is for use with Hspice only. You're using spectre, so this is an unsupported component. You can use "vsource" instead from analogLib, which can be used as an AM modulated source. See the analogLib reference documentation in cdnshelp/cdsdoc for more details.
    For your second problem, you didn't fill the view name in. It needs to be "symbol" (using the browse button will do this if you pick the view).
  • StreamCX
     Thanks, I will try it.
