  3. Wavescan launching problem
  • Views 15126
canuck
canuck over 17 years ago
I'm getting the following error when I try to start the Analog Environment using Cadence version 5.10.41_USR5.90.69:
java: xcb_xlib.c:50: xcb_xlib_unlock: Assertion `c->xlib.lock' failed.
Aborted
*Error*   Failed to launch WaveScan. There is a problem with the DFII installation hierarchy (Exit Code = 214).
For further assistance, contact Cadence Customer Support with the diagnostic information available in the log file.
You can use AWD as your waveform viewer until the problem is resolved.
*Info*    Dumping diagnostic information ....
I changed a few things in my PATH, but nothing seems to help. Does anybody have any ideas? Wavescan did work earlier, but I did install some IBM PDKs recently which should not effect this at all. I'm at a loss to explain this.
  • Austin CAD Guy
    Austin CAD Guy over 17 years ago
     You should contact Customer Support with this question as you may not get a response from the forum.
