  3. How to set up QRC?
  • Views 16785
How to set up QRC?
tkhan
tkhan over 17 years ago
I'm using QRC for the first time and I'm having problems setting it up. I have the assura_tech.lib in my local folder but when I run QRC (EXT71) I get a popup saying "No technology directory found." Then I tried using the Rule Set Builder but once I filled everything in I get another popup saying that its unable to save the ruleset. I tried filling in the QRC fields manually (pretty much just Setup Dir and Reference node) and I was able to extract R and C, but when I want to do RLC(K) it asks for "PEEC User Region" which I don't know how to define... Any help would be appreciated.
Tarek
  • RahulDutta
    RahulDutta over 11 years ago
    Use a region inductance file , the content of the file should be <RegionNumberInterger> (LLx, LLy) (URx, URy) , as Inductance extraction depends on the return path each of these regions for which RLCK needs to be extracted should be mentioned per line , so 10 regions in 10 lines with the above syntax.
