  3. VerilogA Problem in MMSIM-7.1
  • Replies 36
  • Subscribers 139
  • Views 35673
gokce
gokce over 17 years ago
 I am having a problem to simulate my verilogA files under MMSIM 7.1. They work fine under MMSIM-6.0. In spectreout, I get:
ERROR (VACOMP-1008): Cannot compile ahdlcmi module library. Check the log file input.ahdlSimDB/3821_soi12so_Test_Tapeout_Sept09_BinarySearch_veriloga_veriloga.va.BinSearch.ahdlcmi/Linux2.6.11.4-21.9-smp+gcc/ for details. If the compiler ran out of memory, use 'setenv CDS_CMI_COMPLEVEL 0', and try again. If the reason for the failure was a syntax error, contact your Cadence Customer Support representative with the netlist, log files, behavioral model files, and any other information that can help identify the problem.
 In  ahdlcmi.out, I get:
/usr/cds/mmsim-7.1/tools.lnx86/systemc/gcc/4.1/bin/gcc  -march=i486 -ffast-math -O3 -DSYSV -DSVR4 -D_REENTRANT -fPIC   -DconfigSPECTRE -I. -I/usr/cds/mmsim-7.1/tools.lnx86/spectre/ahdlcmi/include -c BinSearch_DcFuncDerLoad.c -o obj/optimize/5.0/BinSearch_DcFuncDerLoad.o || rm -f -f obj/optimize/5.0/BinSearch_DcFuncDerLoad.o;
gcc: error trying to exec 'cc1': execvp: No such file or directory
I attached the log files. Does anyone have an idea?
Gokce
netlist.zip
  • gokce
    I might have understood why the problem is caused, but I have no workaround. There is not a "lib" directory under:
     /mmsim-7.1/tools/systemc/gcc/4.1/install
     This probably causes the problem "cc1 not found" issue. I realised that under an earlier version of MMSIM, I have a directory called lib here:
    /usr/cds/mmsim-6.0/tools/systemc/gcc/install
    In the ahdlcmi.out file that I get when trying to compile my veriloga module, it spits out the LD_LIBRARY_PATH:
    LD_LIBRARY_PATH:  /mmsim-7.1/tools.lnx86/systemc/gcc/4.1/install/lib (and other stuff following this)
    But, as I mentioned, no lib directory is found there. I am not sure why this directory is absent, but I will try reinstalling MMSIM-7.1. I suspect there is something missing in the installation package.
    Andrew Beckett over 17 years ago
    Can you try running:
    /tools/systemc/files/install/ncscGcc.ins
  • gokce
     I get this:
    ncscGcc.ins: line 52: cd: ./tools./systemc: No such file or directory
    It might need some env var setting. I'll have to check - probably tomorrow though.
  • aplumb
    aplumb over 17 years ago
    If that's exactly the error message, check your tools link. I wouldn't expect to see a '.' after the 'tools' in './tools./systemc':
    ln -s tools.lnx86 tools
    ...not...
    ln -s tools.lnx86 tools.
    Andrew (P)
  • gokce
     I think my tools link is fine:
    /mmsim-7.1>cd tools
    /mmsim-7.1/tools>pwd
     It is most likely the issue with the ncscGcc.ins. The line that gives the error is:
    cd $Proot/tools.$install_target/systemc
    I think $install_target is not defined anywhere, so it tries to login to "tools." rather than something like "tools.lnx86" .
    Gokce
  • aplumb
    Yeah, probably something 'uname' derived that's not working.
    Actually $install_target would normally be set by installScape. I've not checked the rest of the script, but try doing:
    setenv install_target lnx86
    Before running the script.
  • gokce
     I set install_target as you suggested. I also needed to set Proot to mmsim-7.1. After doing this, the script worked, but I don't know what it has accomplished. It does return to command line in less than a second without printing out anything (no errors or progress reports).
    OK, but did the missing lib dir get created, and does spectre now work?
