  3. Need help with uni-directional routing in Encounter !
  • Views 14581
Calistudent
Calistudent over 17 years ago
I am using Cadence SoC Encounter tool. How to make sure that routing done using "Trial Route", "Special Route" or "Nano Route" is uni-directional on each layer ? For example, if M2 is horizontal, M3 is vertical and so on...
Also, how to check for routing shorts, i.e. when two nets are shorting after routing ?
Any comments on above two questions would be greatly helpful.
Thanks in advance.
    Andrew Beckett over 17 years ago
    A better place for this question would be the Digital Implementation Forum http://www.cadence.com/community/forums/29.aspx
    It's not really a Custom IC question...
