  3. Cadence Libraries Setup
  • Replies 8
  • Subscribers 136
  • Views 25857
tester
tester over 17 years ago
 Dear All,
Can anyone of you tell me how to setup Cadence libraries so that I can use the default library such as analogLib. I am using IC5141. Thanks a lot in advance.
Have a nice day!
  • skillUser
    skillUser over 17 years ago
    You will need a cds.lib file, preferably in your working directory, with entries somthing like the following:
    define basic $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/etc/cdslib/basic
    define analogLib $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/etc/cdslib/artist/analogLib
    define sample $(inst_root_with:tools/dfII/bin/icfb)/tools/dfII/samples/cdslib/sample
    This file content should work for either  a CDB-based version, or an OA-based version (but dont try to use a mixture of CDB and OA in one file or directory location).
    I hope this is what you were asking?
    Lawrence
  • tester
     Dear Lawrence,
    Thank you very much for your reply. I tried to modify the cds.lib file. In the schematic windows, I clicked  "add instance" and then "browse" to try to look for the default libraries, I got an error message in my CIW window as the following:
    ddsInvokeBrowser: Unable to connect to library brower (60 tries)
    cdsServIpc: ipcISAliveProcess connection timeout
    My questions are: can I modify the tires from 60 to smaller number, say 3 for instance. In addition, what might go wrong?
    Thanks  and have a nice day!
  • tkhan
    tkhan over 17 years ago
     Check Library Path Editor to see that the paths are correct. If one of the paths is written in red, then there is a mistake (i.e. libmanager can't find that path).
  • tester
    Dear All,
    Thank you for those of you helped me in this issue. I have checked the library path and it is right. I believe that something is wrong with the license file. The cadence is installed on my laptop running Linux. However, the license file is located on the institute's file server. What kind of setup that the system administrator of the institution need to do in order for me to access the license file correctly? For instance, shall the institution add my machine's host name into its license file? Thanks a lot in advance.
  • skillUser
     As long as your Linux machine is on the network and can see the license server machine(s), then you should be able to communicate with the license daemon on that machine to obtain licenses.  Ensure that your CDS_LIC_FILE environment variable is set correctly, for example, 5280@lic_server_machine_name  You may need to perform more checks and tests to ensure that the machine and network is set up correctly, for example, run the checkSysConf utility with an argument for the version that you are trying to use (e.g. IC5.1 or IC6.1), can the Linux machine ping the license server, does the Linux machine have the loopback address and machine name set up correctly?
    Hopefully this information will help.  If not, and you are still stuck in the water, create a Service Request with Cadence Customer Support.
    Cheers,
    Lawrence.
  • tester
    Dear Lawrence,
    Unfortunately, I am still stucking into this. It will be nice if you can be more specific about checkSysConf and loopback address. I tried to ping the server, and it works. In addition, the CDS_LIC_FILE is also set correctly. THanks and have a nice day.
  • skillUser
    The checkSysConf utility should be part of your Cadence tool installation, it is found under the <cds_install_dir>/tools/bin directory. If you cannot find it, you can download the latest version of the tool from the online support site, or you can download Lic+Config Utils from the Downloads site which contains checkSysConf plus other things.  The following link take you to the checkSysConf page on the self-help site which provides more information on setup and usage: checkSysConf self-help.
    For the "loopback" I was referring to the following entry in the /etc/hosts file:
    127.0.0.1               <machine_name> localhost.localdomain localhost
    I hope that this answers your questions.
    Lawrence.
  • tester
    Dear Lawrence,
    Thank you very much for your help. I have fixed the problem. Have a nice day!
