  3. Abstract generator problem
  • Views 14921
tungthanhhoang
tungthanhhoang over 17 years ago
All,
I run "Abstract generator" tool to  generate LEF file for standard cells. I pass all of the stelps, including Pin, Extract and Abstract.
But, when I export LEF file, it is created but no content inside.
Have you met the same problem and solution for that ?
 B.R
  • skillUser
    skillUser over 17 years ago
    Hi Tung Thanh,
    Is your technology information set up correctly?  For example, does the tech file have a prRules section, a prViaTypes section ?
    Which version are you using of the tools (e.g. what does "abstract -W" return, are you using icfb (CDB-based) or virtuoso (OA-based) for the design framework?)
    Have you looked at the Abstract tutorial?
      `cds_root abstract`/tools/dfII/samples/tutorials/abstract
    I hope that this information helps you to generate a LEF file.
    Lawrence.
