  3. Generating .lib file from layout
  • Views 22343
govilv
govilv over 17 years ago
I am trying to generate my own .lib file from the layout I've designed in Virtuoso. I tried to use SignalStorm, but figured out that I do not have license for it. Could anyone please suggest any other tool to do this?
Also, does SignalStorm come along with the standard university package? I remember having it in 2006-07, but after that it was discontinued for some reason. Any info will be helpful.
Thank you.
Raj.
  • mariek
    mariek over 16 years ago
    Hi Raj,
    Depending upon the functionality of your layout, there are several options for creating a dotlib.
    1) Encounter LIbrary Chracterization is part of the Encounter Timing System and useful for digital std_cells and I/Os. http://www.cadence.com/rl/Resources/datasheets/library_characterizer_ds.pdf
    2) Spectre MDL is a flexible solution for more complex circuits.  Results need to be post-processed into dotlib format.  http://www.cadence.com/rl/Resources/conference_papers/dtp_cdnlive2006sv_STA_Tseng.pdf
    3) Virtuoso ADE-XL has DCM (Design Characterization and Modelling)
    http://sourcelink.cadence.com/en/search/DisplayHtmlDoc.jhtml;jsessionidsl=0JBRRHGCN1YNZLA0BEBCFEQ?param1=http://sourcelink.cadence.com/docs/files/Release_Info/Docs/adeGXL/adeGXL6.1.3/DCM_GettingStarted.html?param2=null?param3=Manuals?param4=?param5=/software/cadence/sldocs/SL3/Release_Info/Docs/adeGXL/adeGXL6.1.3/DCM_GettingStarted.html@en_col?param7=Virtuoso%20Analog%20Design%20Environment%20GXL%20User%20Guide%20--%204.%20Design%20Characterization%20and%20Modeling%20(Product%20Version%20%206.1.3)
    I don't have any details on how these are bundled with university packages.
    Best regards,
    Marie Kunesh
  • sprrenga
    sprrenga over 13 years ago
    Hi, I am trying to generate .lib for my custom cell using Virtuoso ADE DCM(Design Characterization and Modelling). DCM tool just generates a template based on the user provided values for delay, power and area. Is there any way to generate .lib completely in an automated way ?
  • mariek
    mariek over 13 years ago
    Automated is a tall order for a custom cell; however, you should review the Virtuoso Foundation IP Characterization datasheet:
     http://www.cadence.com/rl/Resources/datasheets/Virtuoso_Foundation_IP_Characterization.pdf
    This technology was acquired from Altos and has replaced DCM in ICADV12.1. It is a more automated approach for library characterization.  Without knowing more about the function and process node of your custom cell, it is difficult to know if this would be a better solution than DCM.
