  3. display packet information 'defaultPacket' not found
  • Subscribers 136
  • Views 13758
Malolo
Malolo over 17 years ago
Dear all,
Sorry if i'm repeating any questions that were already solved but i did a search and could found any relating info.
I'm using IC 5141, during initialization, the first line in CIW window  is a warning:
*WARNING* The display packet information 'defaultPacket' for display was not found.
when trying to layout a circuit, another warning notice came with the title " undefined packets" : "there are undefined  packets found. Most likely, the display resource file (display.drf) for a library was not merged.  To merge a display.drf file, use ....................  "
My question is: are these two problems related? how to solve them?
 I'm using  NCSU CDK and have  "cds.lib, .cdsinit, display.drf, .cdsplotinit" files placed in my working directory.  First 3 files are copied from  "cdssetup" folder in  ncsu-dk-1.5.1 packet and last fie was downloaded from the internet.
Really a newbie here, so any suggestions are appreciated!
Malolo
  • dmay
    dmay over 17 years ago
    Yes, these two problems are related. Every layer defined in your technology file needs to have a display packed defined in a display.drf file. It could be as simple as having your display.drf in the wrong location and Cadence is not loading it by default. You can manually load your display.drf using this command:
    drLoadDrf("/path/to/display.drf")
    You can find our what packets you need by dumping your technology file. From your CIW, go to the Tools menu and then Technology File Manager. On the form that comes up, choose your technology library, Select All choices and specify a file to dump the information into. Open the dumped file and search for techDisplays. You'll find all of your layers and purposes in the first two columns and the third column will give you the expected packet name for that layer. This same packet name must also be defined in your display.drf.
    For example, in your techfile, you might see something like this:
     ;( LayerName    Purpose      Packet          Vis Sel Con2ChgLy DrgEnbl Valid )
      ( default      drawing      defaultPacket      t nil nil t nil )
    Your display.drf will need something like the following:
    drDefinePacket(
    ;( DisplayName  PacketName           Stipple    LineStyle  Fill       Outline    [FillStyle])
     ( display      defaultPacket        circles    solid      silver     silver     outlineStipple)
    You can edit your display settings graphically. From your CIW, choose Tools->Display Resource Manager. You can choose to Edit or Merge. The Merge allows you to combine packet information from one display.drf with another. The Edit will bring up a GUI that will allow you to modify color and stipple information for each layer. Then you can use File->Save to dump out your modified display.drf.
    Derek
