  3. ocean -nograph error
  • Subscribers 133
  • Views 4370
nigam214
nigam214 over 16 years ago
I am very new to ocean plateform and cadence tool. In my simulation, konsole screen display takes most of the time and I want to disable it. I found that "ocean -nograph" does the same. I am trying to use -nograph option but its not work. I don't get any log or output file. Could you please help me to resolve the issue. Screen log and ocean script is given below.
### ocean log - 1 ###
$ ocean -log log/test.log -nograph -replay test.ocn
*WARNING* Could not locate rgb.txt file in /usr/lib/X11
*WARNING* This file is required for color operations with the non-graphical
*WARNING* X server and many WARNING messages may follow this one!
/u/55/55/cadence/5.1.41/lnx86/IC5.1.41/tools.lnx86/dfII/bin/Xndx: error while loading shared libraries: libgdbm.so.2: cannot open shared object file: No such file or directory
*WARNING* Unable to open -nograph X Window Display "finkum:500.1"
*WARNING* (using "exec /u/55/55/cadence/5.1.41/lnx86/IC5.1.41/tools.lnx86/dfII/bin/Xndx :0&").
*WARNING* Xndx output may be found in file /tmp/Xndx<pid>.log
### ocean log - 2 ###
$ ocean -nograph test.ocn log/test.log
### test.ocn ###
; load("./test.ocn")
; ocean -log log/test.log -nograph -replay test.ocn
time_start = getCurrentTime()
of = outfile("./output/test")
sprintf(v_data "Start time of simulation is %s\n", time_start)
fprintf(of v_data)
println(v_data)
drain(of)
exit
    This is covered in sourcelink solution 11494094. You need to install the RPM package gdbm on the machine. For example:
    > rpm -q -f /usr/lib/libgdbm.so.2
    gdbm-1.8.0-26.2.1
    The version number may vary, depending on your OS version.
    This package must be installed for "nograph" modes to work, as it is required by
    the
    Xndx "null" X server.
  • nigam214
    thankyou Andrew. I will try to install this RPM.
  • Ducatte
    Ducatte over 12 years ago
    Has the installation of that lib solved your problem? In my case I still have the same error:
    *WARNING* Unable to open -nograph X Window Display "node03.cluster.ic.unicamp.br:500.1"
    *WARNING* (using "exec /tools/cadence/IC5141/tools.lnx86/dfII/bin/Xndx :0&").
    How does I solve it?
    Kind regards,
    The rgb.txt file missing shouldn't be enough to make it exit. More info on that part can be found in Solution 11593064 .
    Did you look at the /tmp/Xndx<pid>.log file? It may have given some more clues...
  • Ducatte
    On the log file it shows the following error:
    Couldn't open RGB_DB '/usr/lib/X11/rgb'
    Binding TCP socket: Address already in use
    Cannot establish tcp listening socket: Address already in use
    Trying to connect an existing tcp listening socket...
    Any  idea?
    Just to make it clear, I want to run ocean in command line, so I'm calling the program as:
    >> ocean -nograph
     It might be that something else is using the port - or that you have too many "-nograph" sessions running on the same machine.
    You could try using:
    setenv CDS_XNDX_OFFSET 1  # or a number from 1 to 9
    or:
    export CDS_XNDX_OFFSET=1
    (the first is for csh, the second for bash/ksh).
    before running icfb -nograph. Hopefully that will help.
