  3. How to prevent from ocean to print unwanted messages on...
  • Subscribers 133
  • Views 16961
How to prevent from ocean to print unwanted messages on screen
Geser
Geser over 16 years ago
i am running ocean scripts from command prompt like
ocean < script.ocn
in this case i see a lot of messages on the screen. I don't want to see all this messages. I want to see only messages that i need. The messages i will print with printf commands inside OCEAN script.
I know i can forward all outputs to file like
ocean < script.ocn > log.txt
but in this case AFAIK i will be unable to print anything on the screen
So, how can i hide all OCEAN output, but still be able to print on screen messages i need?
Thanks, Alex
  • Geser
    Sorry, fixed text
    Use something like this in your OCEAN script:
     fprintf(stderr "blah blah blah\n")
    I just did this:
    user> ocean -restore runSimMod.ocn > log.out
    blah blah blah
    user>
    All the main output goes into log.out, but anything fprintf'd to stderr appears on the screen.
  • Geser
    THanks. It works!
  • TFTandOLED1
    TFTandOLED1 over 12 years ago
     It indeed works! Thank you so much,  Andrew!
     Maofeng
    We also plan to add an environment setting to control  this which can be added to the top of your OCEAN script:
    envSetVal("asimenv.misc" "includeSimLogInOCEAN" 'boolean nil)
    This isn't released yet; it's probably going to be in IC616 ISR6 (April 2014 timeframe). Also, there's a possibility it might change - but that's the current plan.
