  3. unbound variable
  • Views 17755
unbound variable
tester
tester over 17 years ago
Dear All,
I am using IC5141 and currently I am run into a problem: After typing "icfb&", I got the following error message on the CIW window:
unbound variable - home.
Can anyone give me a hand? Thanks.
    Andrew Beckett over 17 years ago
    My guess is that you have a variable home in your .cdsinit file. This may be in your working dir, your home dir, or in <ICinstDir>/tools/dfII/local - or possibly elsewhere if in IC613 (can try typing "cdswhich .cdsinit" if you're using IC61).
    It may be in a file loaded from the .cdsinit too.
    I don't think it's in the Cadence software; it's in some customization file.
  • tester
    Dear Andrew,
    Thank you very much for your help. This is the exact solution to my problem since I setup an unnecessary variable in .cdsinit before.
    Have a nice day!
