  3. Questions Regarding the Virtuoso XL Layout
  • Views 15918
tester
tester over 16 years ago
Dear All,
I am a beginner of XL Layout and I have a question regarding the auto generating basic layouts from schematic. According to some tutorial materials, in the Virtuoso XL Layout window, after clicking Design->Gen From Source, I should be able to see both the boundary box and instance cells. However, the only thing that I can see is the boundary box. (in the original schematic, I have mos, cap, res etc) By the way, I am using IC5141. Thanks.
    archive over 16 years ago
    The components are there but you can not see them because there are so tiny
    Try to zoom in at the point where the two axies are crossed , normally should somewhere near there
    Regards
    Nick
  • Vabzter
    Vabzter over 16 years ago
          Press shift f to get the layout views. Press ctrl f to get the boundry views.
    Hope this helps..
    Cheers
    Vabzter
  • Vabzter
     Hello
                Press Shift f to get the layout views. Press Ctrl f to get the boundary views.
    Hope this helps
    cheers
    Vabzter
