  3. ADE(GUI) DC analysis query
  • Views 1767
eppramod
eppramod over 16 years ago
Hello experts, I have one basic query regarding dc sweep analysis done using ADE (GUI mode). The query is whether we can give an expression in the start-stop section of the sweep range? The expression will evaluate to a numerical value.I want to change the range based on the numerical value of another variable. Thanks, Pramod
  • Dirk Bormann
    Dirk Bormann over 16 years ago
     Hi Pramod,
     at least for AC analysis you can use variables in this way: VAR("yourvariable").
     Best regards,
    Dirk
    Dirk,
    That's true if you are using IC61. If using IC5141, you cannot use the VAR()
    syntax, and these particular fields do no accept non-numerical values.
    So the workaround would be to specify the analysis via an include file. Put the
    spectre statement in a text file, with something like this:
    dc dc param=temp start=startVal stop=stopVal step=stepVal annotate=status
    Add it to your "Model Libraries" (as good as anywhere else) and then define
    design variables startVal, stopVal, and stepVal.
    Best Regards,
    Dirk Bormann wrote, on 09/10/09 08:06:
    > Hi Pramod,
    > Best regards,
    > Dirk
    > You received this email because you subscribed to notifications for the
    > Custom IC Design Forum. To unsubscribe, log in, go to forums, and change
    > your forum subscriptions.
    > http://staging2.cadence.com/community/forums/ForumSubscriptions.aspx
  • eppramod
    Hi Andrew, Thanks for the reply.Yes I am using IC5141 version. Yes,I tried VAR() and it didn't help. Now i will try the workaround you have suggested. Thanks for the help. Pramod
