  3. RHEL5 and ADEXL
  • Views 14971
RHEL5 and ADEXL
Spirito
Spirito over 16 years ago
 Just installed centos 5.3 on x86_64 machine and I can not start ADE-XL , it reports no error but no window pop.
any ideas ?
    First of all, CentOS is not a supported Linux distribution, so no testing is done on that.
    Were there any messages in the CIW (look in the CDS.log, in case you've got them filtered) or in the terminal window? If there is something like:
    *Error* eval: undefined function - _SessionIlCmdWrapper
    *WARNING* A Skill error occurred in function _axlWindowCreateTrigger
    *Error* windowCreateTrigger for viewType (adexl) failed to create a window!
    Then it could be a known issue - you need to ensure that this library,
    /usr/lib/libXm.so.3
    Which is a 32-bit library. It's not sufficient just to have the 64-bit version installed (because Virtuoso is 32bit).
  • Spirito
    Thanks for the help, but I had already openmotif, x86_64 and i386, installed, and all the other required libraries.
    Since we had a centos 5 machine that cadence worked well on, I have reinstalled CentOS 5 with all the packages it offers (talk about paranoid), added the i386 libelf and openmotif , and now everything runs well . the downside is of course that I dont know which package was missing.
    FYI : if you are running ADS DL , make sure that SELinux is disabled  (this holds also for ADS stand alone) and have ur gcc installed.
     Best Regards
    Spirito
