  3. Transfer simulation-data from spectre to Matlab.
  • Views 15261
Picchio
Picchio over 16 years ago
Hi everybody.
I have plot a montecarl histogram using spectre.
I would  to transfer Montecarlo data simulation from spectre to Matlab to elaborate them.
How can i do it?
    The scalar measurements from Monte Carlo appear in a text file, "mcdata" in the "monteCarlo" directory alongside the netlist/psf dir. It's easy enough to read this into another tool.
    Or you could use the "spectre toolbox" in the MMSIM installation directory (see the MMSIM documentation) to read the raw waveform data - assuming you chose to save it - into Matlab, and then you can process it however you like.
    You may find the SKILL code abStats.il in sourcelink solution  11026072 useful too.
