  3. ASSURA 3.1.6 error message
  • Replies 7
  • Views 18462
yoyega
yoyega over 16 years ago
I am working with IC.5.1.4 (Cadence version 07/08) together with austriamicrosystems HitKitV3.70. I am trying to run DRC with ASSURA 3.1.6 on my layout but I get the following error message:
Reading the design data...
*WARNING* Inconsistent DBUPerUU in the design
*WARNING* 160 is not the same as 1000
*WARNING* Cell:  PRIMLIB pcapacitor symbol
Failed to build VDB.
*****  dfIIToVdb terminated abnormally  *****
*WARNING* dfIIToVdb exit with bad status.
*****  aveng terminated abnormally  *****
*WARNING* /ic_tools/v0708/cds/ASSURA.3.1.6/tools/assura/bin/aveng exit with bad status
*WARNING* Status 256
*WARNING* Assura execution terminated
 I am using austriamicrosystems setup files with design rules. I have been trying to find why are these errors appearing but still have no clue. Can anyone give me any tips?
Thanks and regards,
Pedro
    My guess is that you're trying to run DRC on an inappropriate view. It's complaining about a pcapacitor symbol, which should NOT be in a layout. Symbols often have this DBUperUU.
    Perhaps you accidentally tried to run the DRC on an extracted view? That could well have instances of pcapacitor to represent the extracted parasitics, and I can imagine this would trigger this kind of error.
  • yoyega
    thank you very much for your answer Andrew. What you say makes sense, but I am sure that I am running the DRC on the layout view. In fact my design has only 2 views: schematic and layout. I don't have an extracted view yet.
     Any other clues/ideas?
    Pedro
    Can you try using the "Tree" command (under Design->Hierarchy, I think) to check if you've accidentally managed to get any pcapacitor cells in the layout somehow.
    Also check in the DRC form that you've got the correct lib/cell/view filled in.
  • yoyega
    Hi Andrew, thanks for the clue, it looks like you were right. I have 2 pcapacitor symbols on my layout view! Well, I don't know how did they get there, but I definitely do not see these pcapacitors on the Virtuoso Layout Editing window. Do you know how can I do to see them?
    I checked the DRC form and I have the correct values for lib/cell/view fields.
    Pedro
                                              Design Hierarchy
    Library     : tesis_definitivos
    Cell        : phc_lyt
    View        : layout
    Option      : Top to bottom
    Stop Level  : 32
    TECH_C35B4 VIA2_C symbolic (4)
    TECH_C35B4 PD_C symbolic (3)
    TECH_C35B4 VIA1_C symbolic (53)
    TECH_C35B4 ND_C symbolic (3)
    PRIMLIB cpoly layout (2)
    PRIMLIB pcapacitor symbol (2)
    1. Use Edit->Search
    2. Set the search for to be "inst" in "current cellview" and hit the "Add criteria" button.
    3. Set the additional  criteria to be "cellName" == "pcapacitor"
    4. Hit Apply on the form. It should find any pcapacitor instances
    5. Hit the "Select All" (make sure nothing else was selected first)
    6. Use Edit->Delete and the pcapacitors should now be deleted
    After doing these steps, you should have rid yourself of these pcapacitor instances.
    Best Regards,
  • yoyega
     Thank you very much Andrew! It worked! I have ASSURA running now!
  • rrlamichhane
    rrlamichhane over 13 years ago
     You are awesome Andrew. Thanks. That problem was buggin me since yesterday. I made a new account on Cadence just to say thank you to you. :)
