  3. Problem with spectremdl.
  • Views 15812
AnnaS
AnnaS over 16 years ago
Hi All,
I am facing some problem using this command:
spectremdl -batch Netlist.mdl -design nmos_test.scs
The error log is:
.../linux/mmsim6.0.ISR26/tools.lnx86/bin/spectre: line 171:  2013 Segmentation fault      (coredumped) .../linux/mmsim6.0.ISR26/tools.lnx86/spectre/bin/spectre =mdl Netlist.mdl nmos_test.scs
 It will be great if someone can advise how to handle this.
Thanks,Anna
    Anna,
    It's impossible to debug a generic internal error with the data that reproduced it, but I would say that that's rather an old MMSIM version (4-5 years old). You'd be best testing it with MMSIM71 and then reporting it to Cadence support if it is still a problem. It may have been fixed in the meantime.
  • AnnaS
    Thank you for advise. I have tried with versions: MMSIM7101_37E, MMSIM7101_66E, MMSIM7202 but problem still appears. Here is the log from:
    1. MMSIM7101_37E:
    [1]+  Aborted                 (core dumped) ${APPBINPATH}/${PROGRAM} "$@" 0<&3
    2. MMSIM7101_66E, MMSIM7202
     spectremdl: Command not found.
    Anna
    Hi Anna,
    My guess is from the "command not found" cases that the installation does not have the "tools" link at the root of the MMSIM installation.
    MMSIM72 has not been released yet, so I'm guessing you must have some "early adopter" build.
    That said (assuming that the naming convention for your installations matches our version numbers (roughly), it would seem that there is still a problem with your examples in recent subversions.
    So my advice is to provide those testcases to Cadence Customer Support (you can log a service request via sourcelink - links to support should be found on the drop down menus on the Cadence web site), so that we can investigate, try to find workarounds, and get the problem to R&D to fix the bug.
    Best Regards,
