  3. ocean script - corner list
  • Replies 10
  • Subscribers 133
  • Views 7033
jugemu1234
jugemu1234 over 16 years ago
Hi there,
 When I plan to run several specific corner simulations as in following,
myCorner0='(tt,-40,1.5)
myCorner1= '(tt,125,1.4)
myCorner2= '(ff,-40,1.6)
I noticed "foreach" structure is sort of redundant way because obviously not necessary corners will be included much.
foreach(myMOS '("tt" "ff")
foreach(myTemp '("-40" "125")
foreach(myVdd '("1.4" "1.5" "1.6")
;;;code here
So could you anybody suggest me how to construct efficient ocean script code?
Thanks in advance.
    There's a couple of ways you could achieve this. First with a list of lists:
    foreach(corner '(("tt" -40 1.5) ("tt" 125 1.4) ("ff" -40 1.6))
      myMOS=car(corner)
      myTemp=cadr(corner)
      myVdd=caddr(corner)
    Or another is to have a foreach with multiple loop variables:
    foreach((myMOS myTemp myVdd) '("tt" "tt" "ff") '(-40 125 -40) '(1.5 1.4 1.6)
    This will loop over each of the three lists in parallel.
    Best Regards,
  • aplumb
    aplumb over 16 years ago
    Another options is to use the 'Distributed' simulation infrastructure. Then you can explicitly assign job names to each iteration, plus you can enable suffixing (with a number) so previous runs for the same job name don't get clobbered.
  • aplumb
    Sorry, wrong thread. A.
  • surreyian
    surreyian over 14 years ago
     Hello Andrew,
     What should be included in the corner list?
    myCors=list("fasthigh" "fastlow" )
    foreach(CornersList myCors
    modelFile(
        '("filepath/typicalmid.scs" "")
    list("/filepath/cornerlist.txt")
    cornerlist.txt is as follows
    CornersVars= list ("process")
    CornersList= list(
    list("fastlow" )
    list("fasthigh")
    I get the error message: ERROR: "input.scs" 13: No section found witht name 'fasthigh' defined in file '/filepath/cornerlist.txt'.
    Your question doesn't make sense (or at least doesn't contain enough information). I can't really see what you're doing with the list("/filepath/cornerlist.txt") line - that would treat that file as a spectre input file - which clearly it isn't.
    Did you mean to do:
    myCors=list("fasthigh" "fastlow")
    foreach(corner myCors
      modelFile(
        list("/filepath/typicalmod.scs" corner)
      ; etc
      run()
  • surreyian
     Hello Andrew,
    I was trying to follow this example.
    http://support.cadence.com/wps/myportal/cos/COSHome/viewsolution/!ut/p/c5/dY1JboMwAEXPwgEim8k2S8AMBokmKFDwBhlEKZMJNEVJTl9ygL6_fPp6gINjUux9J-79IsUECsBRpWqBq8YGtD7chEBGUBKnuQcPwOf7gSr4DzYEJeD47TVNJdAK_KsDmRuziGBdgzECuVy2-ShdQRE2C6aL3VGbXphZPLP66XR6GG6ZHaVTQBt5ShD5pQ6v2Zenbz-lj8V8NsxArKy0INepaKEhUh4Fq4nGvvYkHmP4GJJbdT6Zd62xBjzmr0fWLN-rd7F3f92Z20_tsHWKApJwmVtwG-XLJ7byB81SWQk!/dl3/d3/L2dBISEvZ0FBIS9nQSEh/
    I'm trying to include different process corners and run it using ocean.
    I tried your example:
      modelFile(
        list("/filepath/typicalmid.scs" corner)
      ; etc
      run()
    I got this ERROR: "input.scs" 12: No section found with name `fastlow' defined in file
     Do i need to create a file to keep all the corner file together?
  • surreyian
     the link doesnt seems to work.
    I copied the content from the link.
    How to run parametric analysis over corners using Ocean in IC5141?
    soldiv { word-wrap: break-word; overflow: hidden; }soldiv p { margin-left: 0px; }.solDiv blockquote { margin-left: 25px; }soldefault { font-size: 12pt; }.solDefault font { font-size: 12pt; }
    Error Message
    Nil
    Problem
    You would like to run a parametric analysis over a corners. Say you have model corners "typtyp", "fastfast" and "slowslow". You would like to run a parametric analysis on all these corners. How to do run this using Ocean script?
    Solution
    You can use the following Ocean script to run a parametric analysis over a set of corners.
    ;;; Start of Script
    ocnWaveformTool( 'wavescan )
    simulator( 'spectre )
    design("/home/user/simulation/ampTest/spectre/schematic/netlist/netlist")
    desVar( "vsup"  3.3 )
    myCors = list("typtyp" "fastfast" "slowslow")  ;;; Available corners
    foreach(myModelSec myCors
    myResultsDir = strcat("/home/user/simulation/ampTest/spectre/schematic/" myModelSec)
    resultsDir(myResultsDir)
    modelFile(
    '("/home/user/dummy.scs" "")
    list("/home/user/mySingle.scs" myModelSec)
    analysis('tran ?stop "1u")
    temp( 27 )
    paramAnalysis("temp" ?values '(20 25 30)
    paramRun()
    );;; End of Script
    The above script runs parametric analysis sweeping the variable "temp" for all the corners specified (typtyp, fastfast and slowslow). A total of 9 simulations will be run for the above example. The simulation output directory (psf) will be created with a unique name for all 9 runs reflecting the corner and sweep value. For this case, an example would be,
    /home/user/simulation/ampTest/spectre/schematic/fastfast/temp=25
    Related Solutions
       None
    Return to the top of the page
    Document attributes
    Solution ID:11390018
    Created:11/06/2007 03:58:17
    Last Modified:08/07/2011 20:14:59
    Product:Analog IC
    Product Version:5.1.41
    HW Platform:All
    O/S Version:N/A
    SW Release:
    This approach will only work if you've got a section called "fastlow" in your model file - you need to check the model file and see what sections it has within the file (you'll see a "library" keyword and within that sections - assuming that the model file actually has sections at all).
    The error message suggests that there's no "fastlow" section in the model file.
  • surreyian
    modelFile(
        '("xxx/typicalmid.scs" "")
    model file path xxx/typicalmid.scs only have typicalmid corner
    fastmid corner is in xxx/fastmid.scs
    slowmid corner is in xxx/slowmid.scs
     I tried using
    modelFile(
        '("xxx" ""))
     Fatal error occured: unable to open file "xxx"
    in my case how should i run corner?
    How about:
    foreach(corner '("typicalmid" "fastmid" "slowmid")
      modelFile(
        strcat("xxx/" corner ".scs")
      run()
