  3. ocean script - input.scs copy
  • Replies 14
  • Views 8446
jugemu1234
jugemu1234 over 16 years ago
Hi there,
 What I do not like about ocean scripting simulation is that no netlist nor model info would be stored in psf/ folder. netlist/ folder where those info are housed will be automatically overwritten by new simulation. So it is as default impossible to look back old netlist or model environment as far as I know.
 Therefore I think it would be pretty better to have copy procedure of netlist/input.scs prior to running next simulation. But unfortunately I do not know how to just copy certain file to designated location in ocean script.
Could you suggest me to do this?
Best regards,
    In IC613 you have OCEAN XL which can do this - it uses ADE XL's history mechanism, so you can see the setup from previous runs, including the netlists.
    I think in standard OCEAN scripts (in IC5141 or IC613) you can probably do this:
    envSetVal("asimenv.misc" "numberOfSavedRuns" 'int 5)
    which will auto-save the simulation results (and netlists) for the last five runs. It does this in ADE, and I believe it would also affect OCEAN (although I have not tried it - bit busy today).
  • aplumb
    aplumb over 16 years ago
    Another options is to use the 'Distributed' simulation infrastructure. Then you can explicitly assign job names to each iteration, plus you can enable suffixing (with a number) so previous runs for the same job name don't get clobbered.
  • jugemu1234
     Hi
     Unfortunately mine is still IC5 series. I tried  envSetVal("asimenv.misc" "numberOfSavedRuns" 'int 5) option in my script and it surely copied 5 previous psf folder but not netlist nor input.scs.
    Is there any other way to copy netlist every single simulation?
  • jugemu1234
     Hi aplumb,
     Thanks for your info.
    Quite unfortunate but error message came up as followed when I tried via GUI ADE.
    LBS_CLUSTER_MASTER is not set. Checking DP for LSF setup....
    ERROR (209): The DP environment variables are not set.
    To use the LBS mode, set LBS_CLUSTER_MASTER to the name of the cluster
    master host. To use the LSF mode, set LBS_BASE_SYSTEM to LBS_LSF
    It sounds I need to talk with admin guy but is there any other way to avoid such a painful time?
    Really? I just tried this in IC5141:
    simulator( 'spectre )
    design(  "./simulation/ampTest/spectre/schematic/netlist/netlist")
    path( "./Models" )
    modelFile(
        '("myModels.scs" "")
    analysis('ac ?start "100"  ?stop "150M"  ?dec "20"  )
    analysis('tran ?stop "3u"  )
    analysis('sens ?analyses_list list("dcOp")  ?net list("/out")  )
    analysis('dc ?saveOppoint t  )
    desVar(   "CAP" .8p     )
    temp( 27 )
    run()
    selectResult( 'tran )
    plot(getData("/vin") getData("/out") )
    selectResult( 'ac )
    And after the simulation, I got a "1" directory, which as you can see has the input.scs in it
    andrewb_31> ls -lG {1,schematic}/netlist/input.scs
    -rw-r--r-- 1 andrewb 2280 Sep 23 11:08 1/netlist/input.scs
    -rw-r--r-- 1 andrewb 2280 Sep 23 11:08 schematic/netlist/input.scs
    So it appears to work for me!
    As for the distributed processing option, well, you need to set up distributed processing. It won't work without any setup - I suggest you read the manual on this! <ICinstDir>/doc/distproc/distproc.pdf
  • aplumb
    Quick'n'dirty approach:
    #!/bin/csh
    echo `hostname`"_queue 1" > ./queueConfig.`hostname`
    echo `hostname`" 2" >> ./queueConfig.`hostname`
    $CDSHOME/tools/bin/cdsqmgr ./queueConfig.`hostname`
    echo "LBS Queue Master is `hostname`:"
    echo " setenv LBS_CLUSTER_MASTER `hostname`"
    Copy, paste and enter the "setenv LBS_CLUSTER_MASTER `hostname`" into your terminal, then launch your icfb session.
    Bring up ADE and confirm that `hostname`_queue shows up in the Job Monitor. Since most people run on multi-core machines, I set the number of jobs that can be launched to '2' in the above shell script; adjust as you see fit.
  • jugemu1234
    Yes there is numbered folder as you mentioned, but no "netlist" folder in it apparantly as you can see here.
    tklin13..> pwd
    /MydfII/simulation/sim_osc2_gmbias/spectre/schematic/org/32
    tklin13..> lt
    total 7
    drwxrwsr-x    3 aaaaaaaa eng  512 Sep 23 23:55 ./
    drwxrwsr-x    2 aaaaaaaa eng  512 Sep 24 00:06 psf/
    drwxrwsr-x  137 aaaaaaaa eng 5120 Sep 24 00:06 ../
    I think I am close to complete but something ( or some environmental setting) is missing.
    Thanks very much.
    I wonder if this is because your directory hierarchy has the extra "org" directory in it? Normally the directory structure would be:
    /MydfII/simulation/sim_osc2_gmbias/spectre/schematic - containing netlist and psf dirs
    and then the new numbered dir would be:
    /MydfII/simulation/sim_osc2_gmbias/spectre/32 - containing netlist and psf dirs
    i.e. it copies the "view" directory.
    It may be that the non-ADE-like directory structure is confusing things?
  • jugemu1234
     It seems not.
    I also tried without "org" but no luck. Similarly only psf folder was generated. I have no clue with this.
  • markbeck
    markbeck over 16 years ago
     I'm not explicitly answering your question, but if you were willing to run your simulation entirely within Ocean, you can send the simulation results wherever you like with:
      design("LibName" "CellName" "viewname" "r")
      netlist_dir =strcat(envGetVal("asimenv.startup" "projectDir") "/" "CellName" "/spectre/" "ViewName" "/netlist")
      res_dir = strcat(envGetVal("asimenv.startup" "projectDir") "/" "CellName" "/spectre/" "ViewName")
      netlistDir(netlist_dir)
      resultsDir(res_dir) ; set the results directory for the run
    With this method, you can have a different results directory for each simulation type.  You're still stuck with having to explicitly save/move your results if you want to save them from run to run, but you don't have all of your simulations going into one directory.
