  3. Ocean script method to modify spectre netlist
  • Subscribers 133
  • Views 17180
markbeck
markbeck over 16 years ago
I was trying to figure out how I can modify the netlist that is simulated in ocean.  I would like to have the ability to arbitrarily add instances (of any type) into the netlist that is simulated with the run() command.
I finally figured out that if you have skill statements in your ocean script to that create a file with your new instances that you wish to add.
You can add them into your schematic with:
stimulusFile( "Name of new File" ?xlate nil)
Mark
    Mark,
    I guess this is the same as your question from a couple of days ago, http://www.cadence.com/Community/forums/p/13534/21259.aspx#21259 ?
    I'd been meaning to answer that properly but the day job has been getting in the way this week, so it was still on my pending pile, assuming nobody else had answered it in the meantime.
    The simplest is to either use a modelFile or stimulusFile to add the components. There's no particular need to put them at the bottom of the file, I think. Stimulus files have the benefit that you can refer to a schematic net name by putting [#/netName] and it will get translated to whatever that schematic net name got mapped too - less critical these days when things are fairly predictable. Otherwise you could create a file and include it with modelFiles.
    This could have analysis statements in too, and alters and altergroups. I think if you are using alter/altergroup, you'll probably want to specify the analyses as well in the included file rather than via the OCEAN analysis() function, because the order of the analyses and alters relative to each other _is_ important (I was going to check this out, but haven't had time, so this is based on what I expect to work).
    Potentially SKILL could be written to add to the very bottom of the input.scs (not the "netlist" as you've found), but I only think it's worth the bother if the above approach doesn't work.
  • markbeck
     Ya, I figured out what the magic was to gettting the stimulusFile() to work
    1) include a simulator lang=spectre at the beginning of the included file
    2) include a ?xlate nil in the command.
    e.g.
    I have a file foo.txt which contains:
    alt0 alter dev=S0 param=tran_position value=2
    then in the ocean I have to use:
    stimulusFile("foo.txt" ?xlate nil)
     This includes the file as written and doesn't modify it.
    You don't need to put the "simulator lang=spectre" in the file if you give the filename a ".scs" suffix - that will ensure it is interpreted as spectre syntax.
    And I assume it should have said "param=" not "pram="!
  • markbeck
    Interesting, I didn't know about the .scs suffix.
    thanks for catching the typo, I corrected it.
    Mark
