  3. error in virtuoso 6.1.3
  • Views 15283
mocanual
mocanual over 16 years ago
 i have the following error when i try to simulate usinf hierarchy editor : Cadence Analog Distributed Processing option:  Job `job018' failed with exit status = 1
do you know what could be the problem?
    archive over 16 years ago
    You're using a distributed setup, what load balancing software are you using?  If it's LSF, use something like "bjobs" or "bhist -l" or look at the LSF log file on /tmp of the execution host.
