  3. Need skill code to find the instance orientation from V...
  • Replies 11
  • Views 22706
Need skill code to find the instance orientation from Virtuoso
Aksalara
Aksalara over 16 years ago
Hi All,
          I have a Virtuoso layout and I would like to know the orientation of each instance in the design. I need to find out if its MX or MY or R0 or R180, R90, etc..
[I searched in this forus some info is available on the orientation, but couldn't get to the correct one.]
Appreciate your help in this regard.
Thanks.
Ramanath
  • Aksalara
    Found some useful code (excerpt from this forum), please give your comments:
    let( ( wrOrient)
        foreach( instancepointer geGetSelectedSet( )
          unless( null( instancepointer->orient)
        wrOrient = instancepointer->orient
        case( wrOrient
          ( "R0"
            wrOrient = "R90"
          ( "R90"
            wrOrient = "R180"
    Also please give your suggestion on how to select all the instances..
    ; cellView in the current window
    cv=geGetEditCellView()
    foreach(inst cv~>instances
      printf("Instance %s has orientation %s\n" inst~>name inst~>orient)
    I'll leave it to you to put in whatever code you want to check - your requirements weren't clear beyond that.
  • dmay
    dmay over 16 years ago
    cv = geGetEditCellView()
        case(inst~>objType
            ("inst"
                printf("Inst: %s of %s is oriented %s\n" inst~>name inst~>cellName inst~>orient )
            ("mosaicInst"
                printf("MosaicInst: %s of %s is oriented %s\n" inst~>name inst~>cellName car(inst~>mosaic~>tileArray))
            (t
                printf("Unrecognized instance objType: %L\n" inst~>objType
    The code above gets the instances from the cellview attribute called instances: geGetEditCellView()~>instances
    The code in your second post works from the selected set: geGetSelectedSet()
    If you are working in Cadence 5.1.41, the above code should be all you need. If you are working in Cadence 6.1.x, there are additional objects like vias that will have an orient, but will not be found from the instances attribute. The object type will also be something like "stdVia" or "customVia". If this orientation is important, you would need to loop through cv~>vias.
    Derek
  • Aksalara
    Thank you so much Anrews and Derek.
    In my case I have the gdsii and the techFile, so based on these two data, how should i execute the code given above to get the instance name the corresponding orientation value.
    Appreciate your quick reply.
    Thanks once again,
    Ramanath
  • Aksalara
    Also please mention how to direct the output to a specific file?
    If you don't know what to do given a GDS file and a techFile, then it seems odd that you're asking for SKILL code to find the orientation information? Not sure what you're actually trying to achieve here. After all, if the data comes from GDS, the instance names will be pretty meaningless (stream format does not record instance names).
    First you'd need to do File->Import->Stream and import the GDS file (specify the tech file too) and generate a library containing the design.
    Then open the top level cellView in a window, and use code similar to that shown before.
    I'll base it around Derek's code:
    fp=outfile("report.txt")
        case(inst~>objType
            ("inst"
                fprintf(fp "Inst: %s of %s is oriented %s\n" inst~>name inst~>cellName inst~>orient )
            ("mosaicInst"
                fprintf(fp "MosaicInst: %s of %s is oriented %s\n" inst~>name inst~>cellName car(inst~>mosaic~>tileArray))
            (t
                fprintf(fp "Unrecognized instance objType: %L\n" inst~>objType
    close(fp)
  • Aksalara
    Hi Andrews,
                       The time to create and open a cell view from gdsii & techfile in Virtuoso takes around 30 min, when operating with GB databases.. So, I want to know if there is a method so that the cell creation and view opening can be avoided..
    Anyway, thanks for the script update and it works fine (one bracket is missing and I corrected it at my end).
    Thanks in advance.
    Ramanath
  • aplumb
    aplumb over 16 years ago
    Try using 'strmin' from the command-line. That's what I always use to automate (via Makefile) my stream-in of large data.
    Then at least you have the option of logging into a big machine via SSH and running with '-64' for extra breathing room.
  • dmay
    You requested "skill code to find the instance orientation from Virtuoso", yet it sounds like you want to get the orientation from the gdsii file. Reading gdsii and running Skill code in Virtuosos are two very different tasks. If you wish to read the gdsii, I suggest you do a Google search  on GDSII syntax. I know there is a Perl module on CPAN for reading GDSII. Nonetheless, this forum is not the right place for what you are looking for.
  • Aksalara
    Hi All,
               I will look into streamIn to automate this.
    Anyway, thank you so much for your replies and please close this issue/ticket as the solution has been found.
    Ramanath
