  3. Ocean script sample for MonteCarlo simulation
  • Replies 10
  • Views 21981
lunren
lunren over 16 years ago
Dear all,
 I am new to Ocean script, I am wondering if somebody give me a sample of ocean script for monte carlo simulation.
Links, or paste at here works.
 Thanks a lot
    The simplest way to get a sample script is to set it up using Tools->Monte Carlo in ADE in IC5141 or using "Monte Carlo Sampling" run mode in ADE XL in IC613, and then use the Save OCEAN Script menu in each environment.
    Then you can easily generate your own example from the interactive environment.
    I thought it better to "teach a man to fish" rather than "give a man a fish"...
    archive over 16 years ago
     If you don't have access to the MC gui here's an example:
    ocnWaveformTool( 'wavescan )
    simulator( 'spectre )
    design(  "/simulation/ampTest/spectre/schematic/netlist/netlist")
    resultsDir( "simulation/ampTest/spectre/schematic" )
    modelFile(
        '("/Models/InlineModels.scs" "")
    analysis('tran ?stop "1u"  )
    desVar(   "CAP" 0.8p    )
    envOption(
            'firstRun  t
    converge( 'ic "/vin" "0" )
    converge( 'nodeset "/net5" "0" )
    temp( 27 )
    monteCarlo( ?numIters "100" ?startIter "1"
        ?analysisVariation 'process ?sweptParam "None"
        ?sweptParamVals "27" ?saveData nil
        ?nomRun "yes" ?append nil
        ?saveProcessParams t
    monteRun()
    Although I'm not really sure why somebody would have access to OCEAN, but not the ADE monte carlo user interface ...
    If they're in IC6.1...they can't create this simple monteRun script since there's no MC in ADE-L.  They can only create a huge Ocean-XL non-monteRun() script.
    -Samir
    Yes, but that's the way to do monte carlo in IC61. There is now support for the old fashioned approach from ISR 14 onwards, but I would use that as an intermediate step for compatibility; Migrating to the ADE XL/OCEAN XL methodology has some advantages...
  • lunren
    The problem in our situation is that our model do not have process parameters in the montecarlo model. So if we use ADE to run montecarlo, we need to change model file from time to time (tt, ss, ff, ...). So I use script to run montecarlo in a loop and all the corner are included.
    So why do you want to use monte carlo if there are no process parameters - surely it's meaningless to pick random corners? Monte carlo can't work this way, and I don't think it makes any sense.
    Wouldn't a carefully chosen set of corners be of more value?
  • aplumb
    aplumb over 16 years ago
    There's always MC mismatch-only @ corners. Perhaps that's what they're trying to do.?.
    Andrew,
    Maybe, although statistical mismatch data is normally harder to get than statistical process data, so it seems odd. And even then, I'm not sure randomly changing the corner within a monte carlo has any meaning.
  • aplumb
    Ah, missed that bit about randomized corners. I was thinking more along the lines of nested MC-at-each-Corner.
