  3. "virtuoso" error as a invalid command while opening work...
  • Replies 11
  • Subscribers 133
  • Views 9119
"virtuoso" error as a invalid command while opening work bench for IC610
Bhavsh
Bhavsh over 16 years ago
   1st i installed BASE version of IC 610 and then went for UPDATE followed by HOTFIX.When i installed only a base release,work bench was opening by a command "virtuoso",but after  update and hotfixinstallation , after sourcing script file in terminals of REDHAT Linux,its showing that "virtuoso" is a invalid command.What would be the cause for that??. How can i solve it..??
I didnt get any error while configuring after update installation.But i got 2 errors while configuring after i installed HOTFIX ..errors are :
"....ic6/install/tmp/DFII/-ncvhdl164506.11-s017lnx86.exe not found"
"...ic6/install/tmp/oaRedist 22.04-p049lnx86.exe/share/oainstaller/oaconfig no such a file or directory "
is it any serious prob??
pl Reply soon ...
    You probably still have a .cdsinit in either your home directory, or in the installation under <instdir>/tools/dfII/local
    Try running "virtuoso -nocdsinit"
