  3. Ocean script confusion: illegal duplicate field symbol in...
  • Views 15789
Ocean script confusion: illegal duplicate field symbol in list of fields
lunren
lunren over 16 years ago
Hi all,
 I run ocean script for Monte Carlo simulation. In our model file, we just have mismatch parameters (the foundry do not have process variation for Monte Carlo simulation), so in order to run Monte Carlo simulation, we use for loop structure to run Monte Carlo simulation for each corners (TT, SS, FF, FS, SF). Attached please find part of the ocean script. The simulation runs successfully, however, I was confused by the results. Here is the detail,
When I open mcdata for the TT simulation, the results are fine, for the attached setting, the results are:
82.5428 32.1798
However, for the SS simulation, the results are duplicated:
81.3214 30.8723 81.3214 30.8723
If I added loop variable from 2 to 5 (cor_v=5), the duplication (duplicate the date in the same line) will be twice, three times, four times and five times corresponding to cor_v=2,3,4,5. I am wondering if any body can give me some hints about the problem?
Thanks a lot
ocnWaveformTool( 'wavescan )
simulator( 'spectre )
design(  "/home/dexue/simulation/sim_ldo_C/spectre/schematic/netlist/netlist")
for(cor_v 1 2
analysis('ac ?start "1"  ?stop "10G"  )
analysis('dc ?saveOppoint t  ?param "temp"  ?start "5" ?stop "60"  )
analysis('stb ?start "1"  ?stop "10G"  ?probe "/I0/IPRB0"  )
analysis('tran ?stop "55u"  ?errpreset "conservative"  )
analysis('noise ?start "1"  ?stop "10G"  ?p "/v3p2" ?n ""  ?oprobe ""  ?iprobe ""  )
option( 'scale  "1.0e-6")
temp( temp_v )
  if( cor_v==1
         resultsDir( "/home/dexue/simulation/entheto/60mA_ldo_typeC/spectre/60mA_ldo_typeC_mc/schematicTT" )
         modelFile( '("/home/dexue/managed/pdk/tower18_2008_12/model/all_dh6k.scs" "tt_typ") )
        desVar( "power_in" 3.6 )
        desVar( "iload" 50m )
        desVar( "cload" 200p )
        desVar( "ilow" 30m )
        desVar( "ihigh" 60m )
        desVar( "ripple_amp" 0 )
        desVar( "ripple_freq" 0 )
 temp_v = 37
monteCarlo( ?numIters "1" ?startIter "1"
    ?analysisVariation 'processAndMismatch ?sweptParam "Temperature"
    ?sweptParamVals "37" ?saveData t
    ?nomRun "yes" ?append nil
    ?saveProcessParams t
monteExpr( "Phase_Margin" "getData(\"phaseMargin\" ?result \"stb_margin\")" )
monteExpr( "Gain_Margin" "getData(\"gainMargin\" ?result \"stb_margin\")" )
monteRun()
  if( cor_v==2
         resultsDir( "/home/dexue/simulation/entheto/60mA_ldo_typeC/spectre/60mA_ldo_typeC_mc/schematicSS" )
         modelFile(
             '("/home/dexue/managed/pdk/tower18_2008_12/model/all_dh6k.scs" "ss_high")
        desVar( "power_in" 3.42 )
        desVar( "cload" 1n )
        temp_v = 5
monteRun()
    This is covered in my sourcelink solution 11487734.
    The fundamental problem is that you are defining duplicate monteExpr with the same name. In general, after you call monteRun() (or run() for that matter) it keeps all the previous analyses and outputs - it does not start from scratch again.
    So either move the monteExpr() outside of the loop, or use delete('monteExpr) prior to redefining them again.
    More details and other suggestions are in the solution.
  • lunren
     Very helpful.  Thanks a lot.
     Lunren
