  3. Does Ultrasim support PWLF voltage source (Voltage values...
  • Subscribers 126
  • Views 13548
Does Ultrasim support PWLF voltage source (Voltage values derived from Time voltage file)
ramiabr
ramiabr over 15 years ago
  I'm running a simulation in which i will have to directly import stimuli for an input signal from a file (Which has Time-Voltage pairs ),
The input netlist to Ultrasim simulator is in Hspice format,
There is a Hspice syntax for this, but i want an equivalent replacement in Ultrasim,
V1 net2 0  pwlf /home/pwl_file.in
pwl_file.in file contains
0 0
1E-09 1
Thanks in Advance,
 Let me know incase you have any questions,
    Not seen that syntax before, but you should be able to do:
    V1 net2 0 type=pwl file="/home/pwl_file.in"
    or use spectre syntax:
    simulator lang=spectre
    V1 (net2 0) vsource type=pwl file="/home/pwl_file.in"
  • ramiabr
    Thanks a lot Andrew, i used the below syntax and it works,
