  3. Large text size when importing GDS to Virtuoso
  • Views 16064
Verix
Verix over 16 years ago
 Hi. When I import a GDS file to Virtuoso, the labels are all incredibly large. I tried setting the scale text height field to 0.02 in the import options, but it didn't do anything. If anyone knows how to fix this, I'd be very grateful.
  • Quek
    Quek over 16 years ago
     Hi Verix
    This sounds very strange. If it can be confirmed that the large text height issue is not present in the original gds file (You can use a gds viewer such as our k2 viewer from QuickView product), perhaps the next best thing to do would be to try the latest version of IC5141 or IC613 to see if the problem is still present. By the way, may I know the version of Virtuoso which you are using?
     unix>icfb -W
    OR
    unix>virtuoso -W
    Best regards
    Quek
