  3. spectre save statements
  • Views 20484
MarkSummers
MarkSummers over 16 years ago
Is there any comprehensive documentation spectre save statements.  I may be missing something, but I do not find all the info in spectre -h save.
Specifically some explanation on wildcards and also all the different thigs that can be saved.
 I also found that the subckt paramater did not work as I expected.  If I have block C instantiated in block B which is instantiated in Block A.   Block C has pins VDD, GND, INPUT, and OUTPUT.  VDD and GND are signals that exist at the top-level Block A.  They follow the heiarchy down to connect to block C.  If I use the following statement it does not seem to work
save VDD subckt=C
 I assume this is because VDD is a net on a higher level.  I would hope this save statement would work, since it would make it easy to save all VDD nodes connected to instantiations of C without having to know what they are called.  This would be consistent with assertion syntax.
Finally, if I use asserts do I have to explicitly save the nodes I use for assertions(In tran analysis).  It looked to me like it worked without this.  Do nodes/currents called by assertions get automatically saved. This would be a nice feature.
FYI I am using spectre 7.1.1.221
  • MarkSummers
     I did some experiments and it seems that nodes( I actually checked currents) are saved for assert calculations.  I used assertions to check for max and average currents when I had nothing saved in the schematic.  I saved no voltages and no currents.  The calculations reported back values that was consistent when currents were saved and when they were not.  If this is a built in feature, it is a good one and something that should be advertised.
    Confirmation of this and any info on my other questions would be appreciated.
    archive over 16 years ago
    You should be able to get more information on Wildcarding in Save statements in the following link.
    http://sourcelink.cadence.com/docs/files/Release_Info/Docs/spectreuser/spectreuser7.1.1/chap8.html#838518
    Regarding "save VDD subckt=c", since the same signal is passed from A to C, Spectre will save VDD in top level A and not inside C. If you want the value of VDD saved in subckt C, you can use,
     save I1.I2.VDD //I1.I2 is the hierarchical name to subckt C.
    Regarding assert statements, yes, spectre will save node voltages, currents required to solve assert statements even if nothing is saved. However, these signals won't be seen in PSF.
  • MarkSummers
     Thanks for the info.
    It is good to know you do not need to save nodes or currents to get the assertions to work.  This should probably be documented/advertised.
    I understand what you are saying about saving the node inside subcircuit C.  However I think it would be nice if there was a way to save nodes based on subcircuit values and then have the simulator figure which nodes to save in the current design. Although since I don't need to save nodes for assert to work, this is not as critical.
    Hi Mark,
    The subckt parameter only has an effect if there's a wildcard. So if you do:
    save VDD* subckt=C
    it will work - but it would also save VDDA, VDD2 etc as well, if they exist inside C.
    I think it's worth you logging a service request to ask that an enhancement is filed to get it to work even if there is no wildcard. I'm asking you to log a service request, because that way the enhancement can be associated with a specific customer - we can't do that if it's just on the forum here.
