  3. Ocean Script For MonteCarlo Simulation shows incorrect ...
  • Views 15089
Ocean Script For MonteCarlo Simulation shows incorrect results
lunren
lunren over 16 years ago
Hi All,
 My script for montecarlo simulation finished successfully, no error displayed. My script uses for loop so that I can run montecarlo simulation in 5 different corners. I use monteExpr to get simulation results. The results are stored in 5 different directories. However, the results have some problem.
There are some strange numbers following the correct results. I suspect these strange numbers are process number, so If I change the value of ?saveProcessParams from "t" to "nil", the simulation results are correct. However, this is not what I what. I am wondering what's the problem? Thanks,
 Lunren
    I was just about to reply that your question seemed somewhat similar to your previous post. But it seems you've edited the post since you originally posted it so it no longer has the part about getting duplicate information.
    Can you show the "strange numbers" - i.e. what is the output and what is strange about it? Otherwise it's really hard to understand what your problem is.
    Best Regards,
  • lunren
    Sorry for later reply, recently kind of busy.
     The problem just happened once, and for some unknown reason, I can not repeat it. If this happened again, I will ask you again.
     Thanks and have a good day.
