  3. Continuous-time Fourier Transformation
  • Views 17452
tester
tester over 16 years ago
Dear All,
Can anyone show me how to run Continuous-time Fourier Transfromation please? I only find DFT, and it seems for discrete case only. Thanks.
    You can use the "fourier" component in analogLib. The works in conjunction with a transient analysis to perform a Fourier analysis (using a Fourier integral) during a spectre simulation.
    You should be able to find info on this in the documentation for MMSIM; also I believe there is a solution on sourcelink.cadence.com (can't check as I'm on a plane) and also there's a chapter in Ken Kundert's book "The Designer's Guide to SPICE and Spectre" which covers fourier.
  • Tawna
    Tawna over 16 years ago
    Hi Tester,
    there is a comprehenisve sourcelink.cadence.com solution:
    Getting accurate results when using the calculator DFT and the Fourier component.
    http://sourcelink.cadence.com/docs/db/kdb/2006/June/11251190.html
    This describes how to set up both the DFT and the fourier component, as well as plusses and minuses of both.
    best regards,
    Tawna Wilsey
