  3. Assura 3.1 Error -VDB-
  • Views 2568
Thodoros
Thodoros over 16 years ago
Hello!
I am trying to run DRC but I get the following error message:
function density_area_area redefined
*Error* load: can't access file – "umc90N_memory_v14.rul"
*WARNING* Failed to build VDB. Cannot submit DRC Run.
How can I overcome this problem?
Thanks in advance
  • Quek
    Quek over 16 years ago
     Hi Thodoros
    I think perhaps you can resolve the issue quite easily by providing the correct location for the file "umc90N_memory_v14.rul". : )  If the file location is correct, check if it has the correct permission for reading:
    unix>ls -l /your-path/umc90N_memory_v14.rul
     Best regards
    Quek
  • Thodoros
    Thanks for the immediate reply.
     However I cannot find the file umc90N_memory_v14.rul. Could it be a permitions problem?
    Any more ideas?
  • Quek
     Hi Thodoros
    This is precisely the problem. The file is not present. That's why Assura cannot complete the drc run. : )  If there is an "assura_tech.lib" file in your working directory, maybe you can search in the directory listed in the file. Perhaps the file name is wrong? Perhaps the file is in another directory? It would be good if your cad support can help you to locate the file. This is not a file permission problem. It is a missing file problem.
    Best regards
    Quek
    I moved this to the Custom IC Design forum as this has nothing to do with SKILL.
