  3. Colormap overflow, SIGFPE and floating exception
  • Views 15990
Grover
Grover over 16 years ago
Ealier today, Virtuoso 6.1.3 crashed with a Bus Error, and since then it seems that the design I was working on has become corrupt in some way. When I load the adexl setup of my cell and simulate, the CIW says "*Error* SIGFPE caught: possibly caused by (integer) divide-by-zero", aborts the simulation and plots the results from a previous run. If I then press "Simulate" again, the whole program dies with a Floating exception.
When I load another cell (not the one I was using when Virtuoso crashed), it shows this in the simulation job log:
\w *WARNING* (LAYERS-101225): X-Colormap overflow.
\w *WARNING* (LAYERS-101226): Colors snaorange, snagold, snayellow, snalime, snabluegreen, snacadetblue, and snasalmon are not defined.
\o (LAYERS-101002): Please exit some applications to free color cells from X-Colormap
\o (LAYERS-101003): or increase layer pool size by "setenv CDS_LAYER_POOL_SIZE n".
And while this cell does simulate correctly, the traces in ViVa appear in totally different colours after every simulation run. This is confusing, and not like it was before.
I tried deleting my .cdsenv, and setting up a new adexl view for the circuit that's crashing, but to no avail. Could it be that the cell has become damaged somehow? Or is there something wrong with a configuration file, causing the Colormap error? Does anyone know what's gone wrong today?
    What subversion of IC613 are you using? I found a CCR (642307) which was fixed in 6.1.3.500.12. I also found another one (659404) which was related to having spaces in model groups (are you using model groups? If so, try removing the spaces from the names) - this one hasn't been fixed yet.
    As for the  second issue, not really sure about that. Try deleting ~/.ws_state (I'm clutching at straws a little here).
    The right thing to do with both of these issues is to contact Cadence Customer Support via your usual channel.
    Best Regards,
  • Grover
    I've contacted Customer Support, and after a while I finally found out what went wrong: someone applied the latest Hotfix (6.1.3.500.13) without telling me, and this caused Virtuoso to crash when using an old simulator state. The colour replacement problem was caused by one of the scripts in the design kit I'm using, which doesn't work correctly with this new Hotfix.
    Moral of the story: thoroughly test any new Hotfixes before applying them to an environment that others are using...
