  3. How to Handle a floating output?
  • Views 24208
pitter
pitter over 16 years ago
what is a common practice in IC design, when, for example, a Q output od a D flip-flop is not used. Is it left floating, pulled up/down with a resistor or any other load?
 Kind Regards,
pitter.
    It's normally left floating. You can alway attach a "noConn" component from the basic library if you want to avoid the warning marker you would otherwise see in the schematic editor for a floating output.
    Using a resistor is not only a waste of area, but also a waste of power in the case of the Q output being the opposite of the rail to which the resistor is tied.
