  3. Text properties in PVS ?
  • Views 15642
Selef
Selef over 16 years ago
 Hi to ALL,
does everybody know if and how we can use text properties on a DEVICE definition in a PVS (LVS) rule file.
For example in Assura this is made by extractDevice(......textProperty(..))
and in Calibre (SVRF format) by DEVICE....TEXT PROPERTY LAYER
During PVS LVS run there is a translation of SVRF format rules to PVS (masco format),  but the run fails because of the TEXT PROPERTY LAYER command exist on SVRF format with user defined device error.
It seems that computational Build-In language of Calibre SVRF format (using text properties) is not translated properly to PVS (masco) format.
Is it something equivalent to the above statements in PVS (masco format) ?
Stavros
  • Quek
    Quek over 16 years ago
    Hi Stavros
    TEXT PROPERTY LAYER is currently not supported in pvs's pvl format. It will be supported from PVS911 which will most likely be released in April 2010. In the meantime, you would have to remove this cmd from the rules file.
    Best regards
    Quek
  • Selef
    Hi Quek,
    thank you for the information.
    Stavros
