  3. Cadence IC 6.1.3 licensing issues
  • Views 15560
archive over 16 years ago
In the CIW window says that the ' License was checked out successfully' but then when I am trying to open either a schematic or symbol or layout view  ,says that cant find license
Please advice
 Regards
Nik
    Hi Nik,
    The most likely scenario is that you have not had your licenses updated to the IC61X products; there was a revamp of the products in IC61 to introduce tiers. The license you have seen that works is the Framework license ("111") which has existed for years.
    So you'll need to contact your Cadence Account Manager (or whoever you get the licenses from) to request an upgrade to the new products. This is normally a fairly straightforward process, and the new product licenses will also work in older versions (IC5141 USR4 and later).
     Thanks for your reply
     I did manage to open Cadence IC 6.1.3 once, and then after restarting it I saw this licensing issue
    Please note that I am the only one using Cadence license in our site
    I will try to follow your advice
    Many Thanks
    Regards
    Nik
  • Quek
    Quek over 16 years ago
    Hi Nik
    Just to confirm that you are indeed holding ver6.1 licenses, you might want to do more checking using the following cmd:
    unix>lmdiag -c port@serverName licenseFeature
    E.g.
    unix>lmdiag -c 5280@abc Virtuoso_Layout_Suite_L
    unix>lmdiag -c 5280@abc Virtuoso_Layout_Suite_XL
    unix>lmdiag -c 5280@abc Virtuoso_Layout_Suite_GXL
    unix>lmdiag -c 5280@abc Virtuoso_Schematic_Editor_L
    unix>lmdiag -c 5280@abc Virtuoso_Schematic_Editor_XL
    Output should be of version 6.1 similar to the following:
    License file: 5280@abc
    "Virtuoso_Schematic_Editor_L" v6.1, vendor: cdslmd
      License server: abc
      floating license  starts: 13-oct-2009,   expires: 11-jan-2010
      Requests from the same USER/HOST/DISPLAY do not consume a new license
    This license can be checked out
    Best regards
    Quek
