  3. IC613 crashing in linux
  • Replies 7
  • Views 17585
tkhan
tkhan over 16 years ago
My colleauge and I experience frequent crashing (several times a day) when using ADE-L in IC613 sub-version IC6.1.3.500.14. For example, I tried to open the Direct Plot form just now and virtuoso crashed and created panic files for the open cellview. What could be causing this? The end of the log file is attached.
  • crash.txt
  • Quek
    Quek over 16 years ago
    Hi tkhan
    For crash issues, a reproducible testcase would be required. It would be best if you can report this to your local Cadence support. As a workaround, I think perhaps we can try the following:
    a. Try IC613.500.15
    b. Open results brower (Tools->Results Browser) and plot signal using it
    c. Try plotting the same signal using ade-XL. The bug might not be present in ade-XL
    IC614 would be released in Dec. If the above does not work, hopefully IC614 can solve the problem. : )
    Best regards
    Quek
  • tkhan
    Hi Quek,
    The crash is not reproducable, it seems random. The only thing the crashes have in common is that they involve different actions in ADE, the direct plot form was just an example. We have IC613 sub-version IC6.1.3.500.2 for Solaris which doesn't have the crashing issue. I will try upgrading to IC613.500.15 tomorrow.
    BTW we get the following errors in terminal, they come up when performing various functions in ADE. Not sure if its a Cadence issue or a Linux issue:
    Locking assertion failure.  Backtrace:
    #0 /usr/lib/libxcb-xlib.so.0 [0x329767]
    #1 /usr/lib/libxcb-xlib.so.0(xcb_xlib_lock+0x2e) [0x32990e]
    #2 /usr/lib/libX11.so.6 [0x4d240e9]
    #3 /usr/lib/libX11.so.6(XQueryTree+0x25) [0x4d12655]
    #4 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso [0xc0633a2]
    #5 /usr/lib/libX11.so.6(XCheckIfEvent+0x94) [0x4cf6d74]
    #6 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso(_Z19hiiFlushWidgetEventP7QWidget+0x3f) [0xc0632df]
    #7 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso(_ZN16HiQConsoleWindow9updateLogEv+0x131) [0xc100d81]
    #8 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso(_ZN16HiQConsoleWindow11qt_metacallEN11QMetaObject4CallEiPPv+0xb4) [0xc12b5c4]
    #9 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso(_ZN6HiQCIW11qt_metacallEN11QMetaObject4CallEiPPv+0x2f) [0xc12b44f]
    #10 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtCore.so.4(_ZN11QMetaObject8activateEP7QObjectiiPPv+0x605) [0x76e7b25]
    #11 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtCore.so.4(_ZN11QMetaObject8activateEP7QObjectPKS_iPPv+0x3c) [0x76e848c]
    #12 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtCore.so.4(_ZN6QTimer7timeoutEv+0x33) [0x7705c53]
    #13 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtCore.so.4(_ZN6QTimer10timerEventEP11QTimerEvent+0x3e) [0x76efd3e]
    #14 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtCore.so.4(_ZN7QObject5eventEP6QEvent+0x40f) [0x76e688f]
    #15 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtGui.so.4(_ZN19QApplicationPrivate13notify_helperEP7QObjectP6QEvent+0x17f) [0x1e243df]
    #16 /CMC/tools/cadence/IC-6.1.3/tools/QT/lib/libQtGui.so.4(_ZN12QApplication6notifyEP7QObjectP6QEvent+0x182) [0x1e26df2]
    #17 /CMC/tools/cadence/IC-6.1.3/tools/dfII/bin/32bit/virtuoso(_Z20qmotif_timer_handlerPvPm+0x1cb) [0xc14121b]
    #18 /usr/lib/libXt.so.6 [0x753a05a]
    #19 /usr/lib/libXt.so.6(XtAppNextEvent+0xad) [0x753a18d]
    I found more about this here: http://www.edaboard.com/ftopic320216.html
  • Quek
    Hi tkhan
    IC613.500.16 has just been released. Please use this version instead. I am also not sure if this is a Virtuoso or linux issue. Need some troubleshooting to determine this. : )
    Best regards
    Quek
  • tkhan
     Thanks Quek, downloading IC613.500.16 as we speak. Hopefully this solves the problem.
    If it doesn't, please do contact Cadence Customer support. I did some searches based on the stack traces you posted, but it didn't seem to be anything reported so far... So the more info we can get, the better.
  • tkhan
    One of the nice new features in IC614 is that it creates a crash log upon crashing, I suppose these are what I should be sending to Cadence Customer Support. Is Sourcelink the only way to create support requests? I can't create an account for myself since we have a university license so only my network admin can access sourcelink, I'd prefer to be corresponding with customer support since I'm the one using the tools.
    Hi Tarek,
    Unfortunately I can't give much advice because I don't know how the university program works in Canada (or North America in general). You may be able to send emails to support@cadence.com - but I don't know. Your network admin may know the details.
